i have a problem with the PPPOE server.
Clients can login, but sometimes they can’t download anything.
The pppoe connection on the computer show that it sends but receives anything.
When clients disconnect an connect again, it can be that the problem any longer does not exist.
If you search in the forum, you will find good method, how to find correct MTU.
Main idea: start from 1300 value and find border, whan something does not work.
It’s amusingly, it functioned months long with this configuration.
suddenly went nothing more.
If I type “ipconfig /all” (windows) is this the result:
IP Address = 190.160.2.100
Subnetmask = 255.255.255.255
Standart Gateway = 190.160.2.100
DNS Gateway = 190.160.1.1 (IP from MT)
62.xx.xx.xx (DNS from ISP)
If I conect my Laptop, it not function sometimes also.
Are you able to ping both the DNS’s? The gateway? Can you traceroute to any IP? Are you able to resolve things?
Have you talked to the person that configured the pppoe server?
That person should at least have a basic understanding of IP and PPP(oE) and know how to debug.
When the connection are down, I can’t ping the Gateway.
I can’t login with winbox, too.
I only see, that the pppoe connection are stable and it sends information but not receive.
The DNS can’t ping, too.
But when all works fine, I can ping always.
It’s a amusing thing.
Now I have reset the MT and reconfigurated without backup.
I hope that the problem is resolve
Are you by any chance using windows xp service-pack 2? Try turning off all firewalls. Other than that, the problem is unlikely to be pppoe, it’s more likely the transport layer or your client.
Read up on bridging and pppoe. Read how they work together.
You need to know what you are doing. You would possibly benefit the simplicity of a statically routed network instead of a bridged pppoe network. it’s often easier to understand and get right.
OK, I have a similar problem. Network schema is this:
(Clients) <=> (AccessServer) <=> (Router) <=> (The world of WWW)
After upgrading the Router from 2.8 to 2.9.5 a interesing thing did hapened. Some clients that are using Windows98 can connect to the AccessServer without problems but they do not have any browse/ping/anything - the same as the problems of franco. One my colegue found a resolution for this problem. When ip header compression on the client win98 is disabled and there is no problems any more. However it’s not the biggest comfort to go around all your clients and disable that. So my question is - is there a way to solve this problem from the configuration of the Router or AccessServer.
Please, MikroTik team answer this question or if it is an implementation problem/bug, please try to resolve that.
