I’ve set adsl modem recently.
Every seemed to be fine - PPPoE client is up/running, masquarading is set.
Then I noticed that a lot of sites didn’t work (among them HTTPS sites).
I don’t get what’s wrong with it.
I’ve tried to use WebProxy, same problem.
Can anyone help me to solve it?
I know that th answer is on the surface, but I can’t see it.
thanx in advance
try set:
MTU=1492
MRU=1492
Doesn’t work. (
I’ve tried to set IP Proxy, it helps. I guess all work only when connection is initiated by mikrotik.
Could it be that ISP doesn’t support forward or smth like that?
If your Mikrotik is connecting to your dsl via PPPoE have you tried modding your tcpmss in the mangle table? If not try this:
/ip firewall mangle add chain=forward protocol=tcp tcp-flags=syn action=change-mss new-mss=1452 comment="Syn MSS to 1452" disabled=no
ask your provider for MTU and MRU setting
Helped. thanx a lot.
