Hi everyone, I need some help.
Iam trying to use pppoe with two interface bridged, but I can´t ping the public ips obtained from the pppoe session.
The connectivity with radius server is ok and the management Ips works well. But when a pppoe session is established It gets a Public IP from my pool created in mikrotik but cant surf. and I cant ping it. If I put a public IP to the Mikrotik I can ping it so the routing is well.
I need that network be discovered through the Eth0 of the router, so I dont need routing or NAT in Mikrotik. Because of that I bridged the interfaces on mikrotik and need it works in transparent mode.
My conf is:
- Interface eth1 is bridged with interface eth2 called br0 in mikrotik.
- br0 has an IP 10.x.x.2 for management purpose.
- PPPoE Server:
Interface: br0
default profile: - Local address: 190.x.x.2 is that right ???
- Remote address: 190.x.x.100 - 190.x.x.200
- Bridge: br0 ???
Some suggestion???
