I have PPPoE set up on my mikrotik but when it adds the simple queue it adds it at the bottom of the list. Is there a way to change where it will add it?
I wrote a script to move it to the top of the queue list but I can’t get it to work. Can anyone see any problems with this script.
:foreach I in=[/queue simple find dynamic=yes] do={
/queue simple move $I 0
:log info ("moved " . $I)
If I manually move the queue to somewhere near the top of the list of queues, I have found that no matter what I put into this script for the location to move it to, It will move the Dynamic queue back to the bottom of the list queues.
Can anyone tell me why this isn’t working. Everything I have tried doesn’t make a difference. The scrip above will only move the script to the bottom of the list of queues. I wan’t it to move it to the top of the list of queues. What am I doing wrong here?
You have me confused then. The 0 in my script is the position where I am trying to move the queue to. So how would I use the find statement to find the first location. Do you have any suggestions that would work better for me on this script?
I really need something that will move the dynamic queues to the top of the list.
This has been told many times before:
DO NOT USE ITEM NUMBERS IN SCRIPTS!
Code:
/queue simple move $I *1
Instead of *1 which represents internal console number of the 1st item, you should use find statement.
I have this figured out now. Thank you for your help Eugene.
What I did was make a Queue that I disabled at the top of the list with a special name. I then used that to find the location of the top of the list and move the Dynamic Queues above that.
Here is the working script.
:log info ("Moved queue " . $I)
/queue simple move $I [/queue simple find name=“Static Queues - Do Not Remove”]
