PPPOE Radius - "No Password"
Hi All. I’m trying to setup my MT router as a PPPOE Access Concentrator. I think everything is setup, however my Radius debug messages tell me ‘Authenticate: from PPPOE - No Password’. I can only guess that the password is not being sent (testing from WinXP). Any ideas or suggestions here? I have the authentication set to MSCHAP1,MSCHAP2 (not sure if this is right). Any suggestiosn would be appreciated! :shock:
it’s because you are using MSCHAP authenitcation. If you would use PAP then you would be able to see the password as it’s sent in plaintext to the radius server.
Edgars
Yep, that fixed that problem! Say, any idea on how users are supposed to get to the internet? I have them on a private IP address. The subnet itself is masqueraded out, but doesn’t seem to work. The default gateway is just their own address (which maches sense for PPP). Anything specila I need to do?
