Hi All.
We are slowly working our way thru a list of things we want to try out with the RouterOS. One of these has been PPPoE.
I have setup PPPoE up so that if I add a user (or a secret) up I can log in no problems.
I then tell it to use Radius and it connects then disconnects straight way.
We are not using FreeRadius by the way, I have written my own Radius server as part of our software solution.
The error I get back is, “NAS Error”. The user is actually authenticated and a session does start, but then the session ends because of this NAS Error which the RFC is a bit vauge about.
Anyone know what might cause this error? Also, before forget, I also tried another Radius product and it had the same issue of authenticating a user, starting a session then ending the sesson, and the error number is a NAS Error.
I am wondering if this is a config problem, or a more deep Radius issue that I need fix.
Just one more thing. Since I posted this question, I was looking in the Logs in Winbox, and I see that the probelm seems to be “Could Not Determine Local IP Address” then it disconnects…and I am not sure what this means…in RouterOS/Radius world ![]()
Thanks, Jeremy … p.s is this the right area to put this problem? or should I have put it into one of the other topis areas?
