PPPOE redundantly?
I have two RB4011iGS+ that each establish a PPPOE connection to the same provider and get a fixed IP.
Is it possible with RouterOS v7 to make these two connections redundant. So in case of a failure of one device (or reboot) the connection of the PPPOE client should not be interrupted, because on both OpenVPN - connections exist. So in such a case a RB4011iGS+ should have both PPPOE connections.
