I have PPPoE server in R1 and PPPoE client R2, it’s running successfully. But now I am looking to connect other customer R3, which is connected to R2. how can i configure PPPoE client so that it can reach from R1 to R3 PPPoE client.
Hi, you can use “service name”, in the router client or cpe (when you configure the pppoe client) you will se a service name to fill, put the same name that the name of the pppoe server at R2 (for this, you need to have different service name on each pppoe server on each router), if has the same service name the client router will be conect randomly.
Hope I explain it clear.
Regards!!
how can i configure PPPoE Relay in MikroTik. R1 pppoe server , R2 pppoe client, R3 pppoe client which is connecter to R2. so now i need pppoe to R3 from R1 server.
Thank you.
