pppoe router on a stick error!!!
My ros only have one single network port(eth1 rename to wan)。A.I want ros to pppoe dial-up。B.ros send lan data to modwan C.eth1 not only for wan feature but also have lan feature.
Can you help me how to send lan data to modem.
A.pppoe:
(1)eth1 receive vlan8 data(from a modem) in eth1.
(2)I create a vlan8 interface in eth1。
(3)create a pppoe with vlan8 interface。
(4)all is ok.
B.lan data
(1)eth1 reveive untag data(from a modem,use this data is lan data) in eth1.
(2)I create a brige1(it is a brige interface) open vlan filtering(pvid 1),i think ros transform untag lan data to vlan 1 data in ros(pvid feature).
(3)ros defalut add eth1 vlan1 untag port(ros transform vlan 1 data to untag datag,untag port feature)
(4)i set vlan8 in eth1 tag port.
(5)i think all ting is ok. but i have broadcast storm。!!!!!
Your photographs of screen are unreadable to me, so they don’t help.
But conceptually:
A.pppoe seems fine to me
B.lan data: you’re overthinking. Simply use ether1 as base for LAN IP settings
But: are you sure your modem supports this kind of hybrid port usage?
B.I only want use one port for lan and wan.I am sure my modem support this hybrid port.
How do you want to connect more than one device to one ETH port with one cable? Can you explain this phenomena?
Q:Why we must used one port.
A:modem only one port is 2.5G port. if we used this port for wan and lan.we will get more 1G speed。
Q:Why we must push lan data to modem.
A:my modem is a FTTR deivce.if we not push lan data to modem. mesh node will not to used.
