PPPoE Routing
Gents,
I got a minor problem that I was hoping to get some help on. I’m testing a PPPoE/Radius configuration, and so far Mikrotik has been just great and easy to setup. So, I get my public IP and I’m able to do almost everything I want. With that said my problem is that the mail server (i.e. 62.10.23.10) is in the same IP segment that users will be on (i.e. 62.10.23.0/24), which means that they won’t be able to access it.
I tried the following firewall rule to bypass the issue, but there is no joy.
chain=forward action=accept src-address=62.10.23.0/24 dst-address=62.10.23.10
Any help and/or suggestions will be greatly appreciated.
Thanks,
-moya
I basically need a pointer on how to resolve this issue. As you know PPPoE will not, by default, allow peers to see each other. I just want to allow all the users to see the email server that is in the same segment.
Something that I want to avoid is sub-net the block of public IPs that I have.
Any takers?
Thanks,
-moya
