hi i’ve read in mikrotik wiki
“Note: Security issue: do not assign an IP address to the interface you will be receiving the PPPoE requests on.”
does this mean that, if i configured PPPoE server on ether1 then i should not configure a static ip on that interface? as long as i define my local address under ppp profiles which will serve as gateway for my pppoe client? did i understand it correctly?
dont configure static ip so my client won’t be able to connect via static ip on their workstation?
