pppoe server configuration
Hi guys
Just a quick question!
I have one ccr1036. I configured the interface itself (sfp4) as a pppoe server.
My question is, if I create vlan int under sfp4 and create pppoe server on it, would it work?
Actually would they work as a pppoe server at the same time?
Yes you need to create PPPoE Server for each interface or sub-interface, if you don’t clients that send request to this specific VLAN will not get response if there is not any PPPoE server in this interface-vlan
Hi @ingdaka
Thanks for your reply.
I have already pppoe clients under main interface.
But I have also created sub-interface with vlan but it seems it didnt work. All my L2 network in terms of vlan carrying is correct.
I just wondered if main and sub-interface can be created as a pppoe server at the same time and have pppoe clients?
