We have an unusual problem here. Our clients connect using PPPoE for authentication.
Some of our RouterBoards (with RouterOS’s ranging from 4.13 to 5.7) simply drop the connections, forcing everyone to reconnect.
It happens every day around the same time (like if it was generated by a client). Is there anything a client can generate over the ethernet to force de PPPoE server to disconnect all users (or to reset itself)?
There might be different factors that cause disconnect of PPPoE users.
First of all check logs /log print for the reason, user was disconnected from PPPoE server.
We’re trying to figure out why this is happening, what is causing the “Lan” (that is, in fact, a bridge of 11 ethernet ports) to cycle/reset it’s state.
Even stranger than the fact it is happening, is the fact that it happens everyday around the same time…
Is there anything that can be “thrown” on the ethernet that would cause that?
They got the solution? It seems to be some bug Mikrotik, it sometimes falls all customers, sometimes only UBNT. Customers who authenticates the Windows never fall.
No, I haven’t have a clue yet of what’s happening.
On my case, the bridge changes state, dropping all PPPoE connections with it.
I think it’s related to something on the network because it happens every day. Every day around the same time (give or take a few minutes).
Curiously, it happens with different RouterBoards (RB1100, RB433AH, RB800), running different versions of RouterOS.
Don’t know if it’s related, but we had a few problems (similar to this) caused by a misconfigured D-Link DIR-600. With the WPS active, when someone tried to connect via Wireless on the DIR-600, it would drop every user connected via PPPoE on the Routerboard and nobody could reconnect until the DIR-600 was disconnected/powered off.
If one should deactivate WPS on the DIR-600, the problem would go away (what we did for all of them). Until D-Link updated the firmware for the DIR-600, when the problem was gone for good.
So, I have this problem and no clue how to fix it.
