PPPoE server: ether1, bridge1 or both should set proxy-arp?
Hi!
I’m going to install a server with MT 2.9.6
(ether1) (Wlan1 AP)
( bridged as bridge1)
I have both pppoe and normal ethernet users through wlan AP.
Wich interface should I set proxy-ARP on??? bridge1 ether1 or both???
Regards NoXy
You told us nothing about your IP configuration on these interfaces (ether and wlan-ap), or even if you have configured IP for these interfaces at all.
Since proxy-arp is a Layer 3 / IP concept, your question is meaningless without this information.
–Tom
okay
So bridge1 has address 10.1.0.10
client connecting through pppoe has ip from 10.1.0.0/24 subnet
clients using simple ethernet connection (WLAN, no PPPoE) 192.168.1.0/24
regards
NoXy
On which interface do you have an address for 192.168.1.0/24 ?
–Tom
Esetleg ha van kedved jerr fel az sst pont jetos pont com oldalra 1 kis eszmecsere érdekében ha gondolod és van kedved.
Üdv Slys!
