Backbone ↔ L2TP Server + Radius + Management NMS <->L2TP Client + PPPoE Server ↔ WiFi CPE (which have to reach the Management NMS) ↔ PPPoClient
# may/31/2012 09:30:59 by RouterOS 5.16
# software id = ZFR7-4PTV
set 0 arp=proxy-arp auto-negotiation=yes disabled=no full-duplex=yes l2mtu=\
1600 mac-address=D4:CA:6D:22:C0:CB mtu=1500 name=ether10 speed=100Mbps
set 1 arp=enabled auto-negotiation=yes disabled=no full-duplex=yes l2mtu=1600 \
mac-address=D4:CA:6D:22:C0:CC mtu=1500 name=ether9 speed=100Mbps
set 2 arp=enabled auto-negotiation=yes disabled=no full-duplex=yes l2mtu=1600 \
mac-address=D4:CA:6D:22:C0:CE mtu=1500 name=ether7 speed=100Mbps
set 3 arp=enabled auto-negotiation=yes disabled=no full-duplex=yes l2mtu=1600 \
mac-address=D4:CA:6D:22:C0:CD mtu=1500 name=ether8 speed=100Mbps
set 4 arp=enabled auto-negotiation=yes disabled=no full-duplex=yes l2mtu=1600 \
mac-address=D4:CA:6D:22:C0:CF mtu=1500 name=ether6 speed=100Mbps
set 5 arp=enabled auto-negotiation=yes bandwidth=unlimited/unlimited \
disabled=no full-duplex=yes l2mtu=1598 mac-address=D4:CA:6D:22:C0:D0 \
master-port=none mtu=1500 name=ether5 speed=100Mbps
set 6 arp=enabled auto-negotiation=yes bandwidth=unlimited/unlimited \
disabled=no full-duplex=yes l2mtu=1598 mac-address=D4:CA:6D:22:C0:D1 \
master-port=none mtu=1500 name=ether4 speed=100Mbps
set 7 arp=enabled auto-negotiation=yes bandwidth=unlimited/unlimited \
disabled=no full-duplex=yes l2mtu=1598 mac-address=D4:CA:6D:22:C0:D2 \
master-port=none mtu=1500 name=ether3 speed=100Mbps
set 8 arp=enabled auto-negotiation=yes bandwidth=unlimited/unlimited \
disabled=no full-duplex=yes l2mtu=1598 mac-address=D4:CA:6D:22:C0:D3 \
master-port=none mtu=1500 name=ether2 speed=100Mbps
set 9 arp=enabled auto-negotiation=yes bandwidth=unlimited/unlimited \
disabled=no full-duplex=yes l2mtu=1598 mac-address=D4:CA:6D:22:C0:D4 \
master-port=none mtu=1500 name=ether1 speed=100Mbps
/interface ethernet switch
set 0 mirror-source=none mirror-target=none name=switch1
/ip hotspot profile
set [ find default=yes ] dns-name="" hotspot-address=0.0.0.0 html-directory=\
hotspot http-cookie-lifetime=3d http-proxy=0.0.0.0:0 login-by=\
cookie,http-chap name=default rate-limit="" smtp-server=0.0.0.0 \
split-user-domain=no use-radius=no
/ip hotspot user profile
set [ find default=yes ] idle-timeout=none keepalive-timeout=2m name=default \
shared-users=1 status-autorefresh=1m transparent-proxy=no
/ip ipsec proposal
set [ find default=yes ] auth-algorithms=sha1 disabled=no enc-algorithms=3des \
lifetime=30m name=default pfs-group=modp1024
add name=pppoepool ranges=x.x.x.x/x
/port
set 0 baud-rate=115200 data-bits=8 flow-control=none name=serial0 parity=none \
stop-bits=1
set 1 baud-rate=115200 data-bits=8 flow-control=none name=serial1 parity=none \
stop-bits=1
/ppp profile
set 0 change-tcp-mss=yes name=default only-one=default use-compression=\
default use-encryption=default use-mpls=default use-vj-compression=\
default
add change-tcp-mss=default name=l2tp_profile only-one=default \
use-compression=default use-encryption=yes use-mpls=default \
use-vj-compression=default
add change-tcp-mss=default dns-server=x.x.x.x local-address=\
x.x.x.x name=PPPoE only-one=default remote-address=pppoepool \
session-timeout=1d use-compression=default use-encryption=yes use-mpls=\
default use-vj-compression=default
set 3 change-tcp-mss=yes name=default-encryption only-one=default \
/interface l2tp-client
add add-default-route=no allow=pap,chap,mschap1,mschap2 connect-to=\
x.x.x.x dial-on-demand=no disabled=no max-mru=1460 max-mtu=1460 \
mrru=1600 name=L2TP_Client password="xxx" profile=l2tp_profile \
user="xxx"
/queue type
set 0 kind=pfifo name=default pfifo-limit=50
set 1 kind=pfifo name=ethernet-default pfifo-limit=50
set 2 kind=sfq name=wireless-default sfq-allot=1514 sfq-perturb=5
set 3 kind=red name=synchronous-default red-avg-packet=1000 red-burst=20 \
red-limit=60 red-max-threshold=50 red-min-threshold=10
set 4 kind=sfq name=hotspot-default sfq-allot=1514 sfq-perturb=5
set 5 kind=none name=only-hardware-queue
set 6 kind=mq-pfifo mq-pfifo-limit=50 name=multi-queue-ethernet-default
set 7 kind=pfifo name=default-small pfifo-limit=10
/routing bgp instance
set default as=65530 client-to-client-reflection=yes disabled=no \
ignore-as-path-len=no name=default out-filter="" redistribute-connected=\
no redistribute-ospf=no redistribute-other-bgp=no redistribute-rip=no \
redistribute-static=no router-id=0.0.0.0 routing-table=""
/routing ospf instance
set [ find default=yes ] disabled=no distribute-default=never in-filter=\
ospf-in metric-bgp=auto metric-connected=20 metric-default=1 \
metric-other-ospf=auto metric-rip=20 metric-static=20 name=default \
out-filter=ospf-out redistribute-bgp=no redistribute-connected=no \
redistribute-other-ospf=no redistribute-rip=no redistribute-static=no \
router-id=0.0.0.0
/routing ospf area
set [ find default=yes ] area-id=0.0.0.0 disabled=no instance=default name=\
backbone type=default
/snmp community
set [ find default=yes ] address=0.0.0.0/0 authentication-password="" \
authentication-protocol=MD5 encryption-password="" encryption-protocol=\
DES name=public read-access=yes security=none write-access=no
/system logging action
set 0 memory-lines=100 memory-stop-on-full=no name=memory target=memory
set 1 disk-file-count=2 disk-file-name=log disk-lines-per-file=100 \
disk-stop-on-full=no name=disk target=disk
set 2 name=echo remember=yes target=echo
set 3 bsd-syslog=no name=remote remote-port=514 src-address=0.0.0.0 \
syslog-facility=daemon syslog-severity=auto target=remote
/user group
set read name=read policy="local,telnet,ssh,reboot,read,test,winbox,password,w\
eb,sniff,sensitive,api,!ftp,!write,!policy" skin=default
set write name=write policy="local,telnet,ssh,reboot,read,write,test,winbox,pa\
ssword,web,sniff,sensitive,api,!ftp,!policy" skin=default
set full name=full policy="local,telnet,ssh,ftp,reboot,read,write,policy,test,\
winbox,password,web,sniff,sensitive,api" skin=default
/interface bridge settings
set use-ip-firewall=no use-ip-firewall-for-pppoe=no use-ip-firewall-for-vlan=\
no
set 0 vlan-header=leave-as-is vlan-mode=fallback
set 1 vlan-header=leave-as-is vlan-mode=fallback
set 2 vlan-header=leave-as-is vlan-mode=fallback
set 3 vlan-header=leave-as-is vlan-mode=fallback
set 4 vlan-header=leave-as-is vlan-mode=fallback
set 5 vlan-header=leave-as-is vlan-mode=fallback
/interface l2tp-server server
set authentication=pap,chap,mschap1,mschap2 default-profile=\
default-encryption enabled=no max-mru=1460 max-mtu=1460 mrru=disabled
/interface ovpn-server server
set auth=sha1,md5 certificate=none cipher=blowfish128,aes128 default-profile=\
default enabled=no keepalive-timeout=60 mac-address=FE:06:5A:E5:C4:FE \
max-mtu=1500 mode=ip netmask=24 port=1194 require-client-certificate=no
/interface pppoe-server server
add authentication=pap,chap,mschap1,mschap2 default-profile=PPPoE disabled=no \
interface=ether2 keepalive-timeout=10 max-mru=1454 max-mtu=1454 \
max-sessions=0 mrru=disabled one-session-per-host=yes service-name=\
PPPoE_Server
/interface pptp-server server
set authentication=mschap1,mschap2 default-profile=default-encryption \
enabled=no keepalive-timeout=30 max-mru=1460 max-mtu=1460 mrru=disabled
/interface sstp-server server
set authentication=pap,chap,mschap1,mschap2 certificate=none default-profile=\
default enabled=no keepalive-timeout=60 max-mru=1500 max-mtu=1500 mrru=\
disabled port=443 verify-client-certificate=no
/ip accounting
set account-local-traffic=no enabled=no threshold=256
/ip accounting web-access
set accessible-via-web=no address=0.0.0.0/0
add address=10.0.96.254/24 disabled=no interface=ether2 network=10.0.96.0
add address=10.0.97.254/24 disabled=no interface=ether2 network=10.0.97.0
add address=10.0.98.254/24 disabled=no interface=ether2 network=10.0.98.0
add address=10.0.99.254/24 disabled=no interface=ether2 network=10.0.99.0
add address=10.0.104.254/24 disabled=no interface=ether2 network=10.0.104.0
add address=10.0.107.1/24 disabled=no interface=ether2 network=10.0.107.0
add address=x.x.x.x/x disabled=no interface=ether1 network=x.x.x.x
/ip dhcp-client
add add-default-route=no disabled=no interface=ether1 use-peer-dns=no \
use-peer-ntp=no
/ip dhcp-relay
add delay-threshold=none dhcp-server=192.168.1.101 disabled=no interface=\
ether2 local-address=10.0.107.1 name="SKY-Pilot_Relay"
/ip dhcp-server config
set store-leases-disk=5m
set allow-remote-requests=no cache-max-ttl=1w cache-size=2048KiB \
max-udp-packet-size=4096 servers=""
set enabled=yes generic-timeout=10m icmp-timeout=10s tcp-close-timeout=10s \
tcp-close-wait-timeout=10s tcp-established-timeout=1d \
tcp-fin-wait-timeout=10s tcp-last-ack-timeout=10s \
tcp-syn-received-timeout=5s tcp-syn-sent-timeout=5s tcp-syncookie=no \
tcp-time-wait-timeout=10s udp-stream-timeout=3m udp-timeout=10s
/ip firewall service-port
set ftp disabled=yes ports=21
set tftp disabled=yes ports=69
set irc disabled=yes ports=6667
set h323 disabled=yes
set sip disabled=yes ports=5060,5061 sip-direct-media=yes
set pptp disabled=yes
/ip hotspot service-port
set ftp disabled=no ports=21
/ip neighbor discovery
set ether10 disabled=no
set ether9 disabled=no
set ether7 disabled=no
set ether8 disabled=no
set ether6 disabled=no
set ether5 disabled=no
set ether4 disabled=no
set ether3 disabled=no
set ether2 disabled=no
set ether1 disabled=no
set L2TP_Client disabled=yes
/ip proxy
set always-from-cache=no cache-administrator=webmaster cache-hit-dscp=4 \
cache-on-disk=no enabled=no max-cache-size=none max-client-connections=\
600 max-fresh-time=3d max-server-connections=600 parent-proxy=0.0.0.0 \
parent-proxy-port=0 port=8080 serialize-connections=no src-address=\
0.0.0.0
add disabled=no distance=1 dst-address=0.0.0.0/0 gateway=L2TP_Client scope=30 \
target-scope=10
add disabled=no distance=1 dst-address=x.x.x.x/x gateway=x.x.x.x/x \
scope=30 target-scope=10
add disabled=no distance=1 dst-address=x.x.x.x/x type=unreachable
/ip service
set telnet address=\
x.x.x.x/x disabled=no \
port=23
set ftp address="" disabled=yes port=21
set www address="" disabled=yes port=80
set ssh address="" disabled=yes port=22
set www-ssl address="" certificate=none disabled=yes port=443
set api address="x.x.x.x/x" disabled=no port=8728
set winbox address="x.x.x.x/x" disabled=no port=8291
/ip smb
set allow-guests=yes comment=MikrotikSMB domain=MSHOME enabled=no interfaces=\
all
/ip smb shares
set [ find default=yes ] comment="default share" directory=/pub disabled=no \
max-sessions=10 name=pub
/ip smb users
set [ find default=yes ] disabled=no name=guest password="" read-only=yes
/ip socks
set connection-idle-timeout=2m enabled=no max-connections=200 port=1080
/ip traffic-flow
set active-flow-timeout=30m cache-entries=4k enabled=no \
inactive-flow-timeout=15s interfaces=all
/ip upnp
set allow-disable-external-interface=yes enabled=no show-dummy-rule=yes
/mpls
set dynamic-label-range=16-1048575 propagate-ttl=yes
/mpls interface
set [ find default=yes ] disabled=no interface=all mpls-mtu=1508
/mpls ldp
set distribute-for-default-route=no enabled=no hop-limit=255 loop-detect=no \
lsr-id=0.0.0.0 path-vector-limit=255 transport-address=0.0.0.0 \
use-explicit-null=no
/port firmware
set directory=firmware
/ppp aaa
set accounting=yes interim-update=5m use-radius=yes
/queue interface
set ether10 queue=only-hardware-queue
set ether9 queue=only-hardware-queue
set ether7 queue=only-hardware-queue
set ether8 queue=only-hardware-queue
set ether6 queue=only-hardware-queue
set ether5 queue=only-hardware-queue
set ether4 queue=only-hardware-queue
set ether3 queue=only-hardware-queue
set ether2 queue=only-hardware-queue
set ether1 queue=only-hardware-queue
/radius
add accounting-backup=no accounting-port=1813 address=x.x.x.x/x \
authentication-port=1812 called-id="" disabled=no domain="" realm="" \
secret=xxx service=ppp src-address=x.x.x.x/x timeout=300ms
/radius incoming
set accept=no port=3799
/routing bfd interface
set [ find default=yes ] disabled=no interface=all interval=0.2s min-rx=0.2s \
multiplier=5
/routing mme
set bidirectional-timeout=2 gateway-class=none gateway-keepalive=1m \
gateway-selection=no-gateway origination-interval=5s preferred-gateway=\
0.0.0.0 timeout=1m ttl=50
/routing rip
set distribute-default=never garbage-timer=2m metric-bgp=1 metric-connected=1 \
metric-default=1 metric-ospf=1 metric-static=1 redistribute-bgp=no \
redistribute-connected=no redistribute-ospf=no redistribute-static=no \
routing-table=main timeout-timer=3m update-timer=30s
/snmp
set contact="" enabled=no engine-id="" location="" trap-generators="" \
trap-target="" trap-version=1
/system clock
/system clock manual
set dst-delta=+00:00 dst-end="jan/01/1970 00:00:00" dst-start=\
"jan/01/1970 00:00:00" time-zone=+00:00
/system console
set [ find port=serial0 ] disabled=no port=serial0 term=vt102
/system identity
set name="Mvox Rossbach"
/system logging
set 0 action=memory disabled=no prefix="" topics=info
set 1 action=memory disabled=no prefix="" topics=error
set 2 action=memory disabled=no prefix="" topics=warning
set 3 action=echo disabled=no prefix="" topics=critical
/system note
set note="" show-at-login=yes
/system ntp client
set enabled=yes mode=unicast primary-ntp=130.149.17.21 secondary-ntp=\
131.246.1.116
/system resource irq
set 0 cpu=auto
set 1 cpu=auto
set 2 cpu=auto
set 3 cpu=auto
set 4 cpu=auto
set 5 cpu=auto
set 6 cpu=auto
set 7 cpu=auto
set 8 cpu=auto
set 9 cpu=auto
set 10 cpu=auto
set 11 cpu=auto
set 12 cpu=auto
set 13 cpu=auto
/system routerboard settings
set baud-rate=115200 boot-delay=2s boot-device=nand-if-fail-then-ethernet \
boot-protocol=bootp cpu-frequency=1GHz<400DDR> enable-jumper-reset=yes \
enter-setup-on=any-key force-backup-booter=no silent-boot=no
/system upgrade mirror
set check-interval=1d enabled=no primary-server=0.0.0.0 secondary-server=\
0.0.0.0 user=""
/system watchdog
set auto-send-supout=no automatic-supout=yes no-ping-delay=5m watch-address=\
none watchdog-timer=yes
/tool bandwidth-server
set allocate-udp-ports-from=2000 authenticate=yes enabled=yes max-sessions=\
100
/tool e-mail
set address=0.0.0.0 from=<> password="" port=25 user=""
/tool graphing
set page-refresh=300 store-every=5min
/tool mac-server
/tool mac-server mac-winbox
/tool mac-server ping
set enabled=yes
/tool sms
set allowed-number="" channel=0 keep-max-sms=0 receive-enabled=no secret=""
/tool sniffer
set file-limit=1000KiB file-name="" filter-direction=any filter-ip-address=\
192.168.1.101/32 filter-ip-protocol="" filter-mac-address="" \
filter-mac-protocol="" filter-port="" filter-stream=yes interface=all \
memory-limit=100KiB memory-scroll=yes only-headers=no streaming-enabled=\
no streaming-server=0.0.0.0
/tool traffic-generator
set latency-distribution-scale=10 test-id=0
/user aaa
set accounting=yes default-group=read exclude-groups="" interim-update=0s \
use-radius=no
