PPPoE Server Help
Hi all,
I am having some trouble with the PPPoE server. most of it is fine, trouble is the client’s on an AP. i have 3 client’s going through one AP in bridge mode, 1 person connects and all is fine, a second connects and suddenly both are dead.
Please help. Any will be appreciated. Thanx.
If you are using Senao or Pheenet as client device there is problem with 2 or more pppoe connections at same time. We are solving that problem with VPN connection.
mmm, then there is my problem…
I have a Senao AP configured in bridge mode, and a hub connected to that, with the 3 clients on. How can I solve it with the VPN? Just make them login with VPN instead of PPPoE?
You just make them login with vpn and that will solve your problem. Or you coulg give each of them IP, but than you are giving up on authentication and lot of control on user. Best way and we have tried everything is to authenticate via VPN.
