good afternoon everyone. I’m having a problem, which may be a possible bug, when trying to create two pppoe server services on miktoik x86 version 6.43.16. a service is in a vlan and this vlan was created in ether 2, the other service is over ether2 directly. it turns out that the requests that are arriving through vlan are duplicated, and since this is enabled one section per host, the connection is canceled soon after generating fourth error logs. even unchecking the one section per host in the pppoe interface on top of vlan, the problem persists, only when I uncheck this option on the pppoe server that is directly on ether2 I can authenticate pppoe connections from vlan.
