My network is installed with 80 mikrotik devices (routers and APs), connected with rip protocol (10.10.0.0/16), in a range of 10.10.1.0/24,10.10.2.0/24,10.10.xxx.0/24,10.10.254.0/24
I have a main vpn server setup and my clients connect to it with pptp.
I Also want to use vpn server as main pppoe server.
Can this be done? to setup 1 pppoe server? or i have to setup pppoe server in each mikrotik device?
I want pppoe server. With other protocols i am ok .
I want to set one ccr1016 as pppoe server but as i see i cant do it for my network that is not in bridge mode.
That is correct. You could of course make a EoIP link for a certain VLAN and then run PPPoE on that VLAN tunneled through that EoIP link to the CCR, but that is just weird.
