PPPOE SERVER PROBLEM
i have one mikrotik server and my client use static ip address i want to configure a PPPOE server. i already configure but i face some problem.when i connect pppoe server lan card same network every thing ok but atomically pppoe server create one ip address which is already configure my client pc and con flick client ip address.but when i configure different pc than everything ok. any one help me
i attach scan-shoot
so, what’s wrong? if you connect you NIC to clients’ network - you can see clients’ ARP entries on that interface =) what did you expect?
plz read and watch it.one ip is static and one ip automatically created.my pppoe server ip pool is 10.1.1.1/24 and static ip 172.17.8.1/24.look the image carefully one ip static and one ip dynamic and why its create i do not understand.
it is created because ethernet interface named ‘PPPOE’ receives ARP packets from your clients, and adds it to ARP table. it is as it should be =)
what do you want to achieve?
Thk For your replay.I want to configure one mikrotik server and provide 2 service in same network.one is static ip and pppoe server.2 when i configure 2 server work properly but one server have that problem which i explain later.
so simply use one ethernet interface both for routing and as pppoe server
