PPPoE server, routing table
I’m having a problem with 2.9.43…
When I look at the routing table i show all the entries for my PPPoE connections, dst-network, gateway, metrics, but 90% of the interfaces don’t show. It’s causing problems with traceroute and the ability to ping certain devices on the WAN side of the PPPoE Router… I can ping the IP address in question, but when doing a traceroute from either direction it fails at the Mikrotik PPPoE router. My other two PPPoE routers are running 2.9.40 and 2.9.42 and are not experiencing this problem.
Is this a bug with 2.9.43? Should I downgrade?
sending a supout.rif to MT support
OK I just realized the routing-test package is enabled.. Is this done by default when using 2.9.43? because I know I didn’t enable as I’m not using dynamic routing protocols.
I will try disabling and enabling the standard routing package to see if this fixes the problem. I noticed the routing-test package was not enabled on my other two PPPoE servers.
routing-test should not cause such problem, if dynamic routing procols are not used for you.
