I have an Alix board(X86) setup as an Access Point using a PPPoE server( used for bandwidth limitations) also running on the same board. Now I setup a second PPPoE server on the same board, but on an Ethernet interface(also used for bandwidth limitations). A PPPoE client can connect but the Tx/Rx limits do not work on this second PPPoE server. When I look at “Queues”, I a simple queue created for the client connected but it has “unlimited” bandwidth. In other words the values I put in the Tx/Rx limits are not used. How do I correct that? Is that a bug? Or am I trying to do something impossible, ie, a second PPPoE server is not supported? Pls advise. ROS 6.43.2
