Hi everyone.
I’m setting up a PPPoE server in our network with public IP’s (/24 256 addresses) for the clients, and I don’t have problems with configuration number “2” (drawing attached). I created a pool with the publlic IPs, and I don’t apply NAT in the MK core router, so all the clients go to the Internet with their public static Ips.
I want to create the network number “1”, and set up the PPPoE server (ether 2) with another MT router closer to the PPPoE clients. If I use a pool with private address + NAT, all the PPPoE clients use the second router public IP on the ether 1 to go the internet, so no problem with private IPs.
I need to give public IPs to the PPPoE clients, but if I set up a pool with public IPs on this server (on ether 2/router 2) and turn off NAT I can see the PPPoE connections in “active connections” but they can’t go to the Internet, so I don’t know if there is some way to do this without create another subnetted network with public IPs on the second router for the PPPoE clients..
Thanks in advance.
