Dear all ;
Kindly i would like to give you simple information about my network .
I am using pppoe for my wireless clients and some of them need to connect to my internet network for a specific period of time like 12 hours per day .
i need to know , How could i accept their connections within these pre-defined hours and to reject their connection to my network out of this period of time ? ,
currently i do it manualy by disabling their secret to stop them from logging in the network .
i will be waiting your reply with comments eagerly .
if their any article in the forum with the same concept , please refer to it for further information .
with best regards .
Hi all again ;
I think no one get the idea clearly and for this i do not see any reply to this case .
simply if you have a client need to use the internet connection from 6 pm to 6 am daily and no need to access the internet after this period which it will be from 6 am till 6 pm .
so i need to accept his connection during the period 6 pm to 6 am daily and to drop him later .
how to manage this ? , as i said before that i am using pppoe .
waiting your reply eagerly .
with best regards
Hi everybody ;
Can i say that it is not possible in MikroTik OS to do this ?
with best regards .
Hi ;
what a bad luck still no replies to my case .
with best regards .
Hi ;
I am realy sad .
it seems that MikroTik can not do this , but i read before that there is a script used with hotspot to give some clients service for 12 hours per day or less or more according to the requirement .
anyone could help ?
with best regards
you can use RADIUS to do this
i suggest DMA Radius Manager since its compatible with mikrotik out of the box.
Hi ;
Thanks for your reply .
I am not familiar with RADIUS servers , is it part of MikroTik OS ? or it should be installed as well ? , shall i install it in the same pc with MT or another pc ?
i will be waiting your reply with feedback .
with best regards
you will need dedicated PC (Server)
and also you need to buy a license http://www.dmasoftlab.com/cont/home
We use a RADIUS server and run our hotspot through that. Users can be issued with accounts based on bandwidth or time.
All login requests go to the RADIUS server where they are authenticated.
I have not configured a user account which is specifically restricted to 12 hours of the day but one problem we do have, when issuing user accounts limited by bandwidth, is that there seems not to be an easy way to kick a user off once they go over their limit.
We can set idle time but if the user keeps active, they stay connected and exceed their limit.
So I will be interested to see what your solution is - is it possible to terminate a session at a particular time of day and then prevent logon until the next day.
Mikrotik RouterOS support RADIUS disconnect and Change of Authorization, and below attributes (according to the manual) may be changed by while account is online
- Mikrotik-Group
- Mikrotik-Recv-Limit
- Mikrotik-Xmit-Limit
- Mikrotik-Rate-Limit
- Mikrotik-Mark-Id
- Filter-Id
- Mikrotik-Advertise-Url
- Mikrotik-Advertise-Interval
- Session-Timeout
- Idle-Timeout
- Port-Limit
so its easy to kick any user by sending “Session-Timeout” attribute
we used Steel-Belted Radius for many years, but DMA Radius Manager is easy to use and support many many features out of the box
Hi Ahmed
we can talk on ray_ersn@yahoo.com
I will try to help you
Hi Ray ;
an e-mail had been sent to you .
with best regards .
