hello,
i am trying to do the following:
the AP is a pppoe server, pppoe users get authenticated and accounted by the UM on an other machine. the cpe (RB411) is the pppoe client.
the server setup:
/ppp aaa
set accounting=yes interim-update=0s use-radius=yes
/radius
add accounting-backup=no accounting-port=1813 address=10.1.1.1 authentication-port=1812 called-id="" comment="Hotspot and PPPoE" disabled=no domain="" realm="" secret=12345 service=ppp,hotspot timeout=300ms
add name=PPPoE-Pool ranges=10.200.2.100-10.200.2.200
/ppp profile
add change-tcp-mss=yes comment="" dns-server=10.200.2.254 local-address=10.200.2.254 name=PPPoE-Profile only-one=default remote-address=PPPoE-Pool use-compression=no use-encryption=no use-vj-compression=no
/interface pppoe-server server
add authentication=pap,chap,mschap1,mschap2 default-profile=PPPoE-Profile disabled=no interface=wlan1.2 keepalive-timeout=10 max-mru=1480 max-mtu=1480 max-sessions=0 mrru=disabled one-session-per-host=yes service-name=internet
here the client setup:
/ppp profile
add change-tcp-mss=yes comment="" name=PPPoE-Profile only-one=default remote-address=10.200.2.254 use-compression=no use-encryption=no use-vj-compression=no
/interface pppoe-client
add ac-name="" add-default-route=yes allow=pap,chap,mschap1,mschap2 comment="" dial-on-demand=yes disabled=no interface=wlan1 max-mru=1480 max-mtu=1480 mrru=disabled name=pppoe-user password=xxxx profile=PPPoE-Profile service-name=internet use-peer-dns=yes user=dfu1001
the communication from the PPPoE client to the PPPoE-Server and from the server to the User Manager seem to wotk, here the log:
manager,debug,packet received Access-Request with id 18 from 10.200.0.9:53273
manager,debug,packet Signature = 0x364cbfc2d61f3c9d339eae3d373750eb
manager,debug,packet Service-Type = 2
manager,debug,packet Framed-Protocol = 1
manager,debug,packet NAS-Port = 88
manager,debug,packet NAS-Port-Type = 15
manager,debug,packet User-Name = "dfu1001"
manager,debug,packet Calling-Station-Id = "00:0C:42:1B:9F:8D"
manager,debug,packet Called-Station-Id = "internet"
manager,debug,packet NAS-Port-Id = "wlan1.2"
manager,debug,packet MS-CHAP-Challenge = 0xd7b3c0f415acbe560be6ab92c5aca6fb
manager,debug,packet MS-CHAP2-Response = 0x0100f1e219ea64c1536fbae1c3fe3f45
manager,debug,packet 5cf900000000000000009c14bf78cb31
manager,debug,packet 954fc317952a57e36e0696cc5e3ca937
manager,debug,packet 45f7
manager,debug,packet NAS-Identifier = "testrouter02"
manager,debug,packet NAS-IP-Address = 10.200.0.9
manager,debug received remote request 727 code=Access-Request from 10.200.0.9:53273
manager,debug sending Access-Accept to request 727
manager,debug,packet sending Access-Accept with id 18 to 10.200.0.9:53273
manager,debug,packet Signature = 0x936213e22395e0210f39982ef34c33d6
manager,debug,packet MS-CHAP2-Success = 0x01533d34423744323146303131434541
manager,debug,packet 38373543354331313943454439414637
manager,debug,packet 4541443135383542414232
manager,debug,packet MS-MPPE-Send-Key = 0xe9848fd65e685ea4a5398cf0903601c0
manager,debug,packet 7c94a9f549a3989d51f8230990f9a3c5
manager,debug,packet ca06
manager,debug,packet MS-MPPE-Recv-Key = 0xa1eacca1850faa3da2580823296a4d10
manager,debug,packet e1876fce9eda265f3fed1fab49a8cc57
manager,debug,packet ed59
manager,debug,packet Acct-Interim-Interval = 600
manager,debug,packet MT-Rate-Limit = " 1m/1m"
manager,debug,packet MT-Xmit-Limit = 1073727077
manager,debug,packet MT-Xmit-Limit-Gigawords = 0
manager,debug,packet MT-Recv-Limit = 1073615246
manager,debug,packet MT-Recv-Limit-Gigawords = 0
manager,debug,packet received Accounting-Request with id 19 from 10.200.0.9:42197
manager,debug,packet Signature = 0x2d760d524c7014449dce8fb0f6a77ccd
manager,debug,packet Acct-Session-Id = "81400002"
manager,debug,packet Framed-IP-Address = 10.200.2.200
manager,debug,packet Acct-Authentic = 1
manager,debug,packet Event-Timestamp = 1216714219
manager,debug,packet Acct-Status-Type = 1
manager,debug,packet Acct-Delay-Time = 0
manager,debug received remote request 728 code=Accounting-Request from 10.200.0.9:42197
manager,debug sending Accounting-Response to request 728
manager,debug,packet sending Accounting-Response with id 19 to 10.200.0.9:42197
manager,debug,packet Signature = 0xf76ea0843b33a2fad3dae19cfd8d72d3
if i look at the ip addresses on my test cpe i find this:
[admin@PPPoE-Test] > ip address print
ADDRESS NETWORK BROADCAST INTERFACE
0 192.168.100.1/24 192.168.100.0 192.168.100.255 ether1
1 D 10.64.64.72/32 10.200.2.254 0.0.0.0 pppoe-user
i do NOT get an ip address from the pool specified. any suggestions how i can solve this problem ?
regards
Jan
