PPPoE - Simple Queue - Parent Queue in ROS 6.5
I see the latest version of ROS can do “Queue - Parent Queue” in “PPP - Profile” which can i can specify the parent Q to the auto PPP simple queue.
  1. What attribute to use if I want to set “Parent Queue” from radius server?
  2. if not possible or not yet support, what is your suggested possible other way to work around ? :smiley:
Thanks,
anyone ?
I cannot help you my friend but you will not feel alone anymore. Me and many more have the same problem. If you found a solution please, tell me so I will do the same.
Well, it seems not many are interested to use “Parent Queue” in PPPoE deployment.
any input ?
This is relevant to my interest.
Seems jst like introducing a new radius attribute into the MikroTik dictionary and sending that back in an access-accept’s would work.
new Radius attribute should be understandable to Mikrotik also, not only to FR, right? so how to achieve the same if MT will not understand the new attribute?
