pppoe & static ip address with radius
Is there a way to do static ip addrs, with pppoe and radius?
http://wiki.mikrotik.com/wiki/Manual:RADIUS_Client#Access-Accept
Framed-IP-Address - IP address given to client. If address belongs to 127.0.0.0/8 or 224.0.0.0/3 networks, IP pool is used from the default profile to allocate client IP address. If Framed-IP-Address is specified, Framed-Pool is ignored
fewi: Framed-IP-Address works for dhcp, but not for pppoe.
Then that’s a bug. Contact support@mikrotik.com. Framed-IP-Address should most definitely work with PPP.
what version? Framed-Address works fine for v3.28 =)
i’ve got a problem, i’ve used Framed-ip-address but when i’ve mark a fixed IP address they doesn’t figure on IP Pool>Used Addresses and they duplicate the ip on PPP>Active Connections and Ip>addresses.
Any idea to solved it ?
