PPPoE & Static IP on Interface
I would like to achieve the following
A router will establish a PPPoE session with a PPPoE Server. This should be the default route.
Then, if for example I suspend the users account (and the PPPoE Client no longer has an address) the user should use the IP from the dhcp-client.
Is there a dhcp option that I can set that changes the “distance” so I don’t need to make the changes on all of my clients?
