PPPoe to clients side
This is my setup
rb600 AP .-wlan-. rb433 antenna client .-ethernet-. router client
How can i bridge the wlan and ethernet so the client router can accsess the PPPoE server.
I understand that i can use WDS, but will not WDS limits the speed? and making alots of tunnels is just making a mess on ap. is it a other way?
In your situation you can set the clients wireless mode to “station-pseudobridge”.
Then bridge the wlan and ether interface together.
This will allow exactly one device (the router) to access the wlan.
station-pseudobridge will also make brigde auto, not exstra configurasjon on the client or ap side?
Have long time seek after a sulusion as the pseudobrigde, this will also help me the places where i not using the pppoe.
so i have control over how many that are connected. so pepol not just connect a switch after the rb`s
thx very mutch
No configuration is needed on the ap.
On the client you need to bridge wlan and ether interfaces - that’s it.
That won’t be possible with pseudobridge.
When I said you can connect only one device this was true for pppoe-Traffic.
With IP-Traffic however RouterOS allows multiple devices. You would then have to use the bridge-filter to limit by source-mac-address.
However it is in general impossible to prevent a customer from connecting multiple devices.
It was that i meen that then they only can have one unit, on there side. Bad English :smiley:
Thx very mutch again.
