Hi all,
it it possible to use MT based wireless CPE in nat/router mode transparent to PPPoE?
PPPoE authentication might be closed at CPE or at Customer’s devices (PC, Ethernet router, firewall). In first case (auth on CPE) PPPoE client will be added to MT and NAT will be enabled on this “virtual” interface, in the second one PPPoE server will be enabled, with “single user” option, on MT ethernet interface so user will authenticate on CPE itself. This solution has a main drawback: bandwidth shaping profiles need to be applied at PPPoE server (if RADIUS is not used); this means that PPPoE profiles need to be defined on every single CPE installed!!
A solution might be to configure MT CPE in bridge mode, but in this way my network and Customer’s one will be in the same broadcast domain… not safe !!! ![]()
Is there a way to let PPPoE data flow accross MT router?
Rgds
