PPPOE Unresponsive
I am using Mikrotik CCR 1009-8G-1S-1S+ with 6.34.6 release as a BGP router & a PPPOE Server. The issue I am getting is the pppoe server stops responding, even the user showing connected in mikrotik interfaces. The PPPOE server shows the IP address in interfaces but that IP isn’t assigned to the pppoe user. Also when I open the Mikrotik interfaces, it doesn’t shows the live traffic on TX RX columns, means the values becomes static. I have checked the cpu load its hovering around 4-8 %.
I am trying since last month but no solution found. The only solution I found is reboot the mikrotik.
Any solution.
Best Regards
Avdhesh
iGEN Networks
