Hi all,
I’m using MT as Access Concentrator to limit Customers’ traffic, with PPPoE profiles and defined upload/download limits.
Since now this has worked pretty good but suddenly, only on some Customers, upload limit doesn’t work any more: Customers that have 128Kbps limit do >256Kbps upload traffic (P2P)…
Is there a P2P type that PPPoE server profiles is not able to catch ?
I have a simple queue that catches all uknown traffic (p2p) and limit it to download/upload 1Mbps/256Kbps…
In my understanding p2p queue is something that should limit (p2p) the total amount of traffic, while PPPoE profile should limit each single connection, that cannot go over these threshold limits.
if the traffic gets caught as part of the p2p queue, it will not get counted in the pppoe queue. i think you can play around with priorities and tieing it to different interfaces to get around that.
mmmm…the whole p2p upload queue is 256Kbps, and I have single customers that are able to do 300Kbps upload The only way I’ve been able to limit such customers was limiting their upload directly on the CPE, but I’m not very happy with this “distributed” policy, because if I’ll change connections profile this have to be changed on every single CPE
I have to different Internet connection, one for p2p (unknown traffcic with port >1024) and onother one for known traffic (http, ftp, smtp, etc…). The known connection upload was almost full and once I limited customer’s upload on its CPE, it immediatly decreased so all this traffic where not mangled as “unknown”. Before doing this type of limiting I’ve sniffed Customer’s traffic and it was all unknown (port > 1024), so I think that there should be some type of traffic (p2p) that is not correctly mangled
Rgds
