pppoe upload problem
Some of my clients told me about problems with upload. I check this and find that if client have speed limit with queue there is a problem with upload from client to server. I’d tested it on my laptop:
  1. connect to internet through pppoe
  2. run speedtest.net
  3. download test is ok
  4. upload test freeze, lost an internet connection, no traffic to internet ony more but pppoe is still up
  5. only then i reconnect pppoe traffic is up
I test it in another windows computer and no problem! all connection configuration is the same on my laptop and this computer.
is any one can fix this problem?
P.S. there was no such problems on my freebsd pppoe server
any ideas?
i found the solution!
problems is in MS-CHAP! I disable it and leave only CHAP for authentication.
All works fine now
