PPPoE upload speed problem
Our issue with this appears to be resolved with version 7.16rc2
We are conducting more testing to confirm proper resolution - but so far so good!
It only took about 16 months to solve !
Hi All
I am not sure if I have the same issue or something similar
We have a CCR2116 as BNG and FTTH clients complain that their download speeds when on wifi is 170Mbps but upload speed is full speed of the link. Clients have tried multiple routers to rule out a wifi issue but no success.
For eg 400Mbps client will get 170Mbps download and 390Mbps upload when on WiFi at their home. When they do similar tests using a network that uses Cisco they get well over 300Mbps download and upload on the exact same wifi routers.
When they are on cable they will get full download and upload speed. Router is currently on 7.14. L2 MTU on all interfaces is 9000, l3 MTU is 1500 and PPP setting on the BNG has Max MTU set to 1500, Max MRU as 1500 and Change TCP MSS set to yes
I may be running into this issue as well. Did you end up confirming that 7.16rc fixes the issues?
I have the same problem on a CCR2116-12-G (v7.14.2), can you confirm if the problem is solved in version 7.16?
My topology:
ISP ROUTER – 700 Mbps —> CCR2116 – (10G)-- > OLT HUAWEI → Onus
When I use pppoe the upload is limited to 30Mbps but when I use fixed IPs (without pppoe) I get 700Mbps/700Mbps
I have noticed something similar where clients complain of slow speed. It seems that a single stream download runs at max 30Mbps. Personally I have a NAS at home which receives a full dump from DC every Saturday. A few months ago I would receive at a rate of 400Mbps but lately it is only 30mbps. Unfortunately I do not know since which ROS version this is happening as I only noticed a few days ago that my NAS has not been completing its sync due to the speed. I am on ROS 7.16.1
After some time I noticed one other thing.
In my case, the CCR1072 is only used as a PPPoE concentrator, which then routes the traffic to the dedicated CGNAT machine and so on…
PPPoE upload drops proportionally with number of PPPoE users.
I currently have about ~1200 active PPPoE sessions and the CPU is at 2-3% most of the time, but the upload doesn’t go above 200mbps. Everything is rock stable, and I use FQ_Codel queue on limiting the traffic for each PPPoE connection, but there is just no way to get above 200mbps of upload.
None of the cores (under speedtest) go above 50% utilization.
It seems this will be an unsolved problem, as the device is now discontinued for some time. Which is really sad, as it is a real PPPoE concentrator monster with its 72 cores.
Although it’s interesting to see that the problem is not isolated to CCR1072 (at least by what you guys say), so there is still a small beam of hope that this is a problem outside some discontinued device, which means that maybe someday this might get solved.
Our topology looks a bit more complicated, but it is somewhat similar to this with 10g and 100g interfaces. And we don’t have such hard limit of 30Mbps.
EDIT: We are running currently 7.16.2, will update in a few days to 7.19.1, so there might be some changes hopefully
UPDATE:
We just updated our CCR1072s to 7.19.1, the CPU usage is the same, but now the upload goes to about 500Mb/s, it is mostly around 450Mb/s, so there is definitely some improvement.
I don’t know if there were some internal optimizations, the patch notes for the versions in between are really long, so if anyone might have a clue, I would like to be enlightened :slight_smile:
Hopefully we might see more improvements in the future.
