Hi every one I have been using MT for the last 2 dais VERY Impressed as I’m from a Cisco, Lucent,Unix backgroud on the NAS
But I have found some thing I need to do but can’t so here is the qestion
I have a Unix billing system call billmax which allowsv me to control the user.
So for time logging I get the info from the NAS via SNMP which tells me Username, bytes up, down,tty, tickes (time on line) and so on I take the tickes + tickes used and if greater then the ticks allows drop him
same with the bytes used I read allot in the forum about and I think it much easier with SNMP for pppoe as pppoe is an interface the info is there as
IF-MIB::ifName.36 = STRING:
IF-MIB::ifHCInOctets.36 = Counter64: 5526
IF-MIB::ifHCOutOctets.36 = Counter64: 19304
as you can see it’s there but small thing missing
like the info tying to the pppoe number and how long the interface is up for. Once it’s there and as the info is in the system and need’s to be put in the SNMP system this would greatly help
plus a more egent way of disconecting some the runing ssh and running a comand when you dont know the number to KILL agents the user.
