I have MT which i have enabled PPPOE server on one of interfaces and there is about 200 user, now the problem is some users maybe all of them! i dont know, connect using their modem (ADSL Modem) and after he/she wants to open a page the link appears down and no data will transfer and receive from the network, i changed the router but it doesnt solved the problem, i upgrade MT 2.9.50 to 3.25 but i still have poblem and my customers exhusted please help me on this issue you have experice this problem on your network and tell me what to do, i scare to loss my customers in near.
This result in regular disconnects, pretty much every 3 minutes:
Client (Debian, Roaring Pengiun PPPoE) → mtik CPE (pseudo-bridge) → ----- wireless link ------ <— mtik base (PPPoE server)
This works, without disconnect, same hardware:
mtik CPE (pppoe-client) → ----- wireless link ------ <— mtik base (PPPoE server)
RouterOS is 3.25 on both sides. I’ve tried to set keepalive to 0, the link is at -59, CCQ is 90%
it seems it is unknown problem, nobody answer this problem it may related to NIC but i am trying to check it out.
i will tell u if i found the answer.
no packet lost, no bad quality.
Have u checked the switch? It can happen if generate broadcast storm in switch which connect with Router interface (Lan). U can check it by ping from client end to router local address.
Hu raktim,
thanks for your reply i think it is related to the switch by could you please tell me what you mean, which feature should be disabled or enabled?
