PPPOE using IPv6
Hello
I tring to setup pppoe server using ipv6. If in my ipv6 pool i use prefix lenght /64 win7 client take ip but all /64 network is routed to this client.
When i use prefix lenght /128 win7 clinet don’t take ip address.
Who know how assign /128 prefixes via pppoe?
http://wiki.mikrotik.com/wiki/Manual:IPv6_PD_over_PPP
Using pd delegation my win7 pc dont take /128 address
The big problem is that allocations via pppoe to a client are supposed to be at least /64 and recommended /48 according to IPv6 standards.
You MUST normally allocate a bigger or equal to /64 prefix to each client.
So AFAIK the only solution would be to allocate IPs manually, and then you could do whatever prefixing you like.
