hi every body
how to make pppoe using proxy
knowing that the proxy work on hotspot
but i dont know ho to make certine profile go to proxy
note : i have link adressed 192.168.10.1 have 2 line
normal line and proxy line
whats up no answer till now is the question so hard???
Do you mean web(http) proxy?
You could try the setup for transparent proxy:
Wiki - Transparent Proxy
There may be some instructions in the RouterOS manual in the proxy section as well.
yes right, follow the wiki and it would solve your problem. just enable proxy and redirect all port 80 to your MT box
Hi all,
First post here so still consider me a noob! ![]()
I have tried following the wiki for transparent proxy, but I don’t have the option for - > ip - >web-proxy? the webproxy package webproxy-test is installed and I am running 2.9.50.
I also notice that everytime I try change max-cache setting to use more than 7000Kb it just changes back, even when specifying it to use my 512Mb compact flash card. Card is formatted and empty.
Any ideas? what am I missing?
dear all
thanx for all ur answers but u didnt understand my question
i already have a web proxy and do a transperant proxy and itis work fine in hotspot
the question is can i make poxy work on pppoe brodband or not and if yes how ??
thanx alot
