Dear Sirs,
I've setup a PPPoE connection on WAN1 with EOLO ISP, first try everything was fine, test speed was 8.00Mbps .
After 2 days connection was still on but test speed was 1.2Mbps.
I've tried a disconnect then reconnect, still the same.
Reset routerboard to factory default with a blank conf, changed the port for the WAN and still the same.
Connected directly a PC first and another router and the speed was 8.00Mbps.
The ISP said can be a fautly mikrotik hardware,but I've tried today again with the routerboard and speed now is high.
Can someone please give me some advice?
oct/15/2015 15:08:44 by RouterOS 6.32.2
software id = LDRS-FM3M
add comment="Internal Network" name=bridge-local
set [ find default-name=ether1 ] name=WAN1
set [ find default-name=ether2 ] comment=BACKUP name=WAN2
/ip neighbor discovery
set WAN2 comment=BACKUP
set bridge-local comment="Internal Network"
add authentication-types=wpa2-psk management-protection=allowed mode=
dynamic-keys name=wifi_security supplicant-identity=MikroTik
wpa2-pre-shared-key=wifipassword
add authentication-types=wpa-psk,wpa2-psk management-protection=allowed mode=
dynamic-keys name=test wpa-pre-shared-key=test
wpa2-pre-shared-key=test
/interface wireless
set [ find default-name=wlan1 ] mode=bridge security-profile=test ssid=test
add name=dhcp_pool1 ranges=192.168.1.11-192.168.1.20
add address-pool=dhcp_pool1 disabled=no interface=bridge-local lease-time=3d
name=dhcp1
/ppp profile
add change-tcp-mss=yes name=ppp-wan
/interface pppoe-client
add add-default-route=yes allow=pap default-route-distance=1 interface=WAN2
name=ppp-backup password=pwd profile=ppp-wan use-peer-dns=yes user=
userofpppoe
add add-default-route=yes allow=pap disabled=no interface=WAN1 name=ppp-wan
password=pwd profile=ppp-wan use-peer-dns=yes user=userofpppoe
add bridge=bridge-local interface=ether3
add bridge=bridge-local interface=ether4
add bridge=bridge-local interface=ether5
add bridge=bridge-local interface=wlan1
add address=192.168.1.1/24 interface=bridge-local network=192.168.1.0
/ip cloud
set ddns-enabled=yes
add address=192.168.10.0/24 dns-server=192.168.10.1 gateway=192.168.10.1
set allow-remote-requests=yes
add action=drop chain=input comment="Drop Invalid connections"
connection-state=invalid
add chain=input comment="Allow Established connections" connection-state=
established
add chain=input comment="Allow ICMP" protocol=icmp
established
add chain=forward
add action=masquerade chain=srcnat comment=nat-internet-access out-interface=
bridge-local
ppp-wan
bridge-local
/ip service
set telnet disabled=yes
set ftp disabled=yes
/system clock
set time-zone-name=Europe/Brussels
/system identity
set name=MK
/system leds
set 5 interface=wlan1
