Following scenario:
ISP with PPPoE on a BRAS accepting PPPoE Sessios from its customers for Access.
PPPoE Server runs on a Mikrotik ROS Router and sets IP addresses for the connecting PPPoE Clients via Radius.
If customer service is “expired” and should be “blocked”, we assign a different PPPoE IP Range for the same customer via Radius CoA.
The customers IP then changes on the fly and the BRAS forwards (NAT Rules on the SRC IP) the customer then to a external redirect Page to renew its Service. Works perfectly.
Now I’d like to extend this functionality and instead of forwarding the User to a redirect Page, forward instead to Mikrotiks Hotspot Feature.
So - if a SRC IP from a certain Range is detected on the BRAS, traffic should dropped into the enabled Hotspot feature on the same BRAS.
Note, we are then not using the DHCP Server neither Hotspot Pool to assign a customer a Hotspot IP as we have done that via PPPoE/Radius, but instead just need to “inform” the Hotspot that a given SRC IP Range is to be treated through the Hotspot feature.
Did anyone get this kind of scenario to work?
Have tried a few things (NAT an Mangle to forward traffic to the ‘unauth’ chains) but it seems not working/
Thanks!
