Hi all,
I have an ISP (ISP2 interface) with PPPoE connections and it works on the router. I can ping 8.8.8.8 and google.com from the router terminal. But I can’t from a client, I got the following error:
ping: connect: Network is unreachable
I’ve setup nat masq, but it is sill not working. Any idea?
my config:
[admin@MikroTik] > export
# 2023-09-25 12:01:52 by RouterOS 7.11.2
# software id = 6GH8-7J3B
# model = RB4011iGS+
# serial number = AAAF0A39FF87
add name=LAN-BRIDGE
set [ find default-name=ether1 ] disabled=yes name=ISP1
set [ find default-name=ether2 ] name=ISP2
set [ find default-name=ether3 ] name=LAN2
set [ find default-name=ether4 ] name=LAN3
set [ find default-name=ether5 ] name=LAN4
set [ find default-name=ether6 ] name=LAN5
set [ find default-name=ether7 ] name=LAN6
set [ find default-name=ether8 ] name=LAN7
set [ find default-name=ether9 ] name=LAN8
set [ find default-name=ether10 ] name=LAN9
set [ find default-name=sfp-sfpplus1 ] disabled=yes
/interface pppoe-client
add add-default-route=yes default-route-distance=2 disabled=no interface=ISP2 keepalive-timeout=60 name=ISP2-PPPoE user=xxxx
add name=LAN
add name=dhcp-pool ranges=10.0.90.1-10.0.99.100
add address-pool=dhcp-pool interface=LAN-BRIDGE lease-time=521w3d name=dhcp-server
/port
set 0 name=serial0
set 1 name=serial1
add bridge=LAN-BRIDGE interface=LAN2
add bridge=LAN-BRIDGE interface=LAN3
add bridge=LAN-BRIDGE interface=LAN4
add bridge=LAN-BRIDGE interface=LAN5
add bridge=LAN-BRIDGE interface=LAN6
add bridge=LAN-BRIDGE interface=LAN7
add bridge=LAN-BRIDGE interface=LAN8
add bridge=LAN-BRIDGE interface=LAN9
add interface=LAN-BRIDGE list=LAN
add address=10.0.0.1/16 interface=LAN-BRIDGE network=10.0.0.0
set servers=8.8.8.8,8.8.4.4
add action=masquerade chain=srcnat comment=ISP2 dst-address=0.0.0.0 out-interface=ISP2-PPPoE
/ip service
set telnet disabled=yes
set ftp disabled=yes
set www address=10.0.0.0/16
set api-ssl disabled=yes
/system clock
set time-zone-name=Europe/Budapest
/tool mac-server
/tool mac-server mac-winbox
