Hi to all. I would want one information: when the mikrotik creates pppoe in automatic rifle creates I one simple queue. End here all ok. The problem is: how I can render statics this simple queue in such way that does not recreate every time that falls the pppoe? Thanks
you would need to use a RADIUS server of auth and log the sessions to a database.
hth
why radius server?
Rather than using the MikroTik secrets the RADIUS server holds the secrets - then you are able to capture informantion about the PPPoE session.
