PPPoE
Hi all new to the MikroTik.
Looking at the next thing on my want to do that in networking - MikroTik was in my price range so here I am.
Have a 2011UiAS.
Was thinking it was just a bit more then a netgear router I was wrong.
Have it up and running now trying to get it to what i need .
I am on a MAC so I use web page logon.
I have NBN and it needs a PPPoE with user and password to log on as there is on modem at the moment i have the TPG router plugged in to the Mik
Any help would be great.
Just add a PPPoE Client in Interfaces → Add new.
Give it a physical interface of your 2011. This interface must not be a part of a bridge.
-Chris
Thanks for your help.
got it to the stage connected and running-but can not get any bandwidth any ideas?
Thanks for the help got it connect and run but still no internet any thing more you can think could help?
Hi Sector5,
By the fact you are using NBN from TPG - I have to assume you are in Australia (hey, me too!)
Basically, you want to get rid of TPG’s ‘Modem’ and from the NTD (the NBN Box inside your house) plug a network cable straight from the active port, to a port on your RouterBOARD.
Once you have done this, log in to your RouterBOARD and go to Quickset on the left. Select Mode: Router, then for ‘Address Acquisition’ select ‘PPPoE’.
Put in your username and password.
Make sure ‘NAT’ is ticked down the bottom.
Hit apply, and hopefully it does the rest for you.
Thanks.
Thanks Joe
Yea from OZ in Sydney new development so lucked out with the NBN.
You are correct that is what i am doing
Done all this, router tells me that I connected gives me an IP and Gateway still no internet
Hi Sector5,
Feel free to email me joe.goldman -at- gmail -dot- com, if you are trusting I am willing to log in remotely and fix it up for you.
Email me first and I can give you real world Australian contact details ( I live in Coffs Harbour and manage an ISP).
thanks for your help
Simon
hello sector 5 ,
I am from Tasmania and have also problems with the Mikrotik fo an NBN network.
Have you worked your problem out?can you communicate please with your experience?
My Mikrotik RB 750 Gr 2 will not connect. I tried allot.does anyone know ?
Thanks Michael
