Pppt And Public Ip
Good evening everyone
I have two microtiks with public IP on the WAN.
One of these Mikrotiks acts as a PPPT server, the other as a client.
However, when I connect to the Mikrotik that acts as a PPTP client, I get the public address of the Mikrotik that acts as a server, and I would like this not to happen. Is this way?
EXAMPLE
Mikrotik A: Ip Public: 1.1.1.1 - Server PPPT
Mikrotik B: Ip Publici 2.2.2.2 - Client PPPT
Mikrotik B -----------------------------> Mikrotik A (Through PPPT Tunnel) = Ip Public Mikrotik A
I want to go out with my public ip, is there a way?
Thanks for your support
Well, you can use Mikrotik cloud, works as a ddns. It will give you a hostname like 869745684.sn.mynetname.com. /ip cloud. But you can’t hide your IP, if someone knows your hostname will be easy to see your public IP.
If you worried about security check some security good practice guide.
Good morning
Thanks for the reply.
Maybe I explained myself wrong.
I want to go out with my public IP, not with that of the other office where I am connected.
Thank you
