PPSK with RADIUS?
I’m currently using multiple OpenWrt based access points with both WPA2-EAP and WPA2-PSK using a freeradius server for access management. I would like to replace older OpenWrt access points by Mikrotik ones, but a major requirement is, that PPSK using radius is supported.
I’ve noticed, that Mikrotik added PPSK using local configurations, but haven’t seen any information whether radius can be used for WPA2-PSK. My radius server configuration looks like:
"aabbccddeeff"  Cleartext-Password := "aabbccddeeff", Calling-Station-Id == "AA-BB-CC-DD-EE-FF"
                Tunnel-Password:0 = "supersecretpassword",
                Tunnel-Type = "VLAN",
                Tunnel-Medium-Type = "IEEE-802",
                Tunnel-Private-Group-ID = "42"
OpenWrt is very easy to setup, just like:
        option encryption 'psk2'
        option ppsk '1'
        option auth_server 'radius.example.com'
        option auth_secret 'radiusserverpassword'
        option dynamic_vlan '2'
        option 'vlan_tagged_interface' 'eth0'
        option 'vlan_bridge' 'br-vlan'
        option 'vlan_naming' '0'
Question: Does Mikrotik support PPSK with radius? If no, is it planned in the near future?
Thanks,
Arnd
Does that means that Tunnel-Password RADIUS attribute is not supported ?
I am interested in using Mikrotik User Manager RADIUS server implementation with some *WRT PPSK compliant access points.
EDIT : RADIUS protocol smacks as always. Tunnel-Password is not puny string value - it is some binary octets followed by encrypted string of 3 substrings .
No surprise RouterOS does not support some, i’ve only seen support in FreeRADIUS and radsecproxy.
