PPTP almost working
Hello
I success conenct the VPN, from the client (Windows 8.1 VPN native connection) i can surf the web with the mikrotiks ip (the client is in china) and access the local network, i can ping all the pc connected to the mikrotik and it resolves the pc´s name, i can access ftp server with the local address, but i can´t do any of it from the LAN to the remote client, ping does not answer even making the ping from the mikrotik. (I think something is missing in the windows 8.1 client.)
When i try to make the vpn l2tp instead pptp i get l2tp error: key lengh mismatched, mine:128 peer:256, can anybody tell me where i can change the key lengh in the mikrotik router (in windows i don’t find the option…)
Thank you everybody…
