Hi support
I own five ADSL lines and I also own PPTP
All I want is to pull out of the five ADSL lines and not from one ADSL line when using PPTP
what is the way
And thank you very much
PPTP is old, outdated, no encryption so should be avoided. Use a newer/better protocol like L2TP/IPSec or SSTP or other.
I know, but I did Load Balancing for the lines
PPTP clinte was used to open the ban
But it uses only one line of adsl and not all of the adsl fonts
You can load-balance / load-share outgoing traffic. You have no control over incoming traffic unless you have true load-balancing hardware at the ISP providing the ADSL circuits, or your remote client also has a Mikrotik and creates five VPN connections, one to each of your public IP addresses, and distributes traffic across them.
Load-balancing a single client over multiple links which have variable latency generally doesn’t give good results due to out-of-order packet delivery.
