PPTP bridged to Ethernet?
my problem are:
i have a pptp connect from a mikrotik router to a mikrotik router.
the network after the connected mikrotik router works to me…
because the question to my IP do not work…
normaly it must come the webif of mikrotik and then the nat… because nothing…
when i use my smartphone and connect 2th to the mikrotik, the both now in the same net, it work, i can see the webif of the connected mikrotik…
can you me help…???
what must i do for work ???
fail there a bridge ???
the pptp ip are 44.225.95.225 (virtual) with pool 44.225.95.226-254/32
the other net are 44.225.93.193/27
the mikrotik was connect are a route 44.0.0.0/8 → pptp
0.0.0.0/0 → 192.168.178.1 (Fritzbox for local inet)…
best regard
M.Dittmann
