PPTP Can't access LAN devices, only MT through WinBox
Hi everyone
I’ve set up a PPTP to access my MT remotely, however, I am unable to access LAN devices, e.g U*q**ti antennae etc…
I have done some reading and tried advice from other similar posts, but still no luck.
Also when setting ARP to proxy-arp and rebooting, the network basically comes to a standstill.
Would appreciate if anyone could assist.
Thanks.
Current script:
add admin-mac=4C:5E:0C:A2:63:4C arp=proxy-arp auto-mac=no comment=\
    "To view all traffic:" name=bridge protocol-mode=none
set [ find default-name=ether1 ] name=ether1-FIBRE-UP speed=100Mbps
set [ find default-name=ether2 ] l2mtu=1598 mac-address=4C:5E:0C:A2:63:4F name=\
    ether2-CLOUDGATE-PC-INTERNET speed=100Mbps
set [ find default-name=ether3 ] l2mtu=1598 mac-address=4C:5E:0C:A2:63:4E name=\
    ether3-15-VOORJAAR-INTERNET speed=100Mbps
set [ find default-name=ether4 ] l2mtu=1598 mac-address=4C:5E:0C:A2:63:4D name=\
    ether4-EMPTY speed=100Mbps
set [ find default-name=ether5 ] arp=proxy-arp l2mtu=1598 mac-address=\
    4C:5E:0C:A2:63:4C mtu=1492 name=ether5-POWERBEAM-ISO-WIRELESS-BRIDGE-PoE \
    poe-out=forced-on speed=100Mbps
set [ find default-name=sfp1 ] disabled=yes
/interface pppoe-client
add add-default-route=yes allow=pap comment="" disabled=no \
    interface=ether1-FIBRE-UP keepalive-timeout=60 max-mru=1400 max-mtu=1400 \
    mrru=1600 name=ISP1-AFRIHOST-200/100-FIBRE user=
/interface pptp-client
add connect-to=154.117.185.86 mrru=1600 name=pptp-out1 user="Cape Town"
set 0 default-vlan-id=0
set 1 default-vlan-id=0
set 2 default-vlan-id=0
set 3 default-vlan-id=0
set 5 default-vlan-id=0
/ip firewall layer7-protocol
add name=YouTube regexp="^..+\\.(youtube.com|googlevideo.com|akamaihd.net).*\$"
add name=Netflix regexp=\
    "^.+(netflix|nflxext|nflximg|nflxsearch|nflxso|nflxvideo).*\$"
/ip hotspot profile
add name=dhcp ranges=192.168.88.10-192.168.88.40
add name=PPPoE ranges=192.168.88.100-192.168.88.200
add name=pool1 ranges=192.168.88.50-192.168.88.100
add name=VPN ranges=192.168.88.90-192.168.88.100
add address-pool=dhcp authoritative=after-2sec-delay disabled=no interface=\
    bridge name=default
/interface ppp-server
add disabled=no name=ppp-in1 port=serial0 ring-count=0
/ppp profile
set *0 dns-server=192.168.88.2 local-address=PPPoE use-encryption=no
set *FFFFFFFE dns-server=192.168.88.2 remote-address=VPN use-encryption=no
/queue simple
add max-limit=1M/4M name="Tyke DHCP" target=192.168.88.16/32
add max-limit=2M/10M name=atta target=192.168.88.15/32
add max-limit=2M/10M name=Ngamlana target=192.168.88.29/32
add max-limit=10M/20M name="Bardien Static" target=192.168.88.10/32
add max-limit=2M/10M name=Dunno target=192.168.88.26/32
add bridge=bridge interface=ether2-CLOUDGATE-PC-INTERNET
add bridge=bridge interface=ether5-POWERBEAM-ISO-WIRELESS-BRIDGE-PoE
add bridge=bridge interface=ether3-15-VOORJAAR-INTERNET
add bridge=bridge interface=ether4-EMPTY
/interface pppoe-server server
add authentication=pap disabled=no interface=bridge keepalive-timeout=5 \
    max-mru=1400 max-mtu=1400 mrru=1600 one-session-per-host=yes service-name=\
    Internet
/interface pptp-server server
set enabled=yes
add address=192.168.88.2/24 interface=bridge network=192.168.88.0
add address=10.0.0.2 network=10.0.0.0
add address=192.168.88.4 interface=ether3-15-VOORJAAR-INTERNET network=\
    192.168.88.4
add address=192.168.88.0/24 interface=bridge network=192.168.88.0
/ip cloud
set ddns-enabled=yes
/ip dhcp-client
add add-default-route=no dhcp-options=hostname,clientid disabled=no
# DHCP client can not run on slave interface!
add add-default-route=no dhcp-options=hostname,clientid disabled=no interface=\
    ether4-EMPTY
/ip dhcp-server lease
add address=192.168.88.16 client-id=1:f4:28:53:db:d0:49 mac-address=\
    F4:28:53:DB:D0:49 server=default
add address=192.168.88.18 client-id=1:c4:4e:ac:12:7b:7 mac-address=\
    C4:4E:AC:12:7B:07 server=default
add address=192.168.88.17 client-id=1:6c:c2:17:7f:b:8c mac-address=\
    6C:C2:17:7F:0B:8C server=default
add address=192.168.88.15 client-id=1:c8:3a:35:41:4d:80 mac-address=\
    C8:3A:35:41:4D:80 server=default
add address=192.168.88.29 client-id=1:30:96:fb:81:bd:79 mac-address=\
    30:96:FB:81:BD:79 server=default
add address=192.168.88.14 client-id=1:74:83:c2:ee:9d:b6 mac-address=\
    74:83:C2:EE:9D:B6 server=default
add address=192.168.88.10 client-id=1:9c:b6:54:a4:5c:4d mac-address=\
    9C:B6:54:A4:5C:4D server=default
add address=192.168.88.26 client-id=1:58:d9:d5:1a:d7:98 mac-address=\
    58:D9:D5:1A:D7:98 server=default
add address=192.168.88.0/24 comment="default configuration" dns-server=\
    192.168.88.2 gateway=192.168.88.2 netmask=24
set allow-remote-requests=yes servers=8.8.8.8,8.8.4.4
/ip firewall address-list
add address=0.0.0.0/8 comment="Self-Identification [RFC 3330]" list=bogons
add address=10.0.0.0/8 comment="Private[RFC 1918] - CLASS A # Check if you need \
    this subnet before enable it" list=bogons
add address=127.0.0.0/8 comment="Loopback [RFC 3330]" list=bogons
add address=169.254.0.0/16 comment="Link Local [RFC 3330]" list=bogons
add address=172.16.0.0/12 comment="Private[RFC 1918] - CLASS B # Check if you ne\
    ed this subnet before enable it" list=bogons
add address=192.168.0.0/16 comment="Private[RFC 1918] - CLASS C # Check if you n\
    eed this subnet before enable it" disabled=yes list=bogons
add address=192.0.2.0/24 comment="Reserved - IANA - TestNet1" list=bogons
add address=192.88.99.0/24 comment="6to4 Relay Anycast [RFC 3068]" list=bogons
add address=198.18.0.0/15 comment="NIDB Testing" list=bogons
add address=198.51.100.0/24 comment="Reserved - IANA - TestNet2" list=bogons
add address=203.0.113.0/24 comment="Reserved - IANA - TestNet3" list=bogons
add address=224.0.0.0/4 comment=\
    "MC, Class D, IANA # Check if you need this subnet before enable it" list=\
    bogons
add address=192.168.88.0/24 comment="Internal Subnet" list=internal-nets
add action=add-src-to-address-list address-list=Syn_Flooder \
    address-list-timeout=30m chain=input comment="Add Syn Flood IP to the list" \
    connection-limit=30,32 protocol=tcp tcp-flags=syn
add action=drop chain=input comment="Drop to syn flood list" src-address-list=\
    Syn_Flooder
add action=add-src-to-address-list address-list=Port_Scanner \
    address-list-timeout=1w chain=input comment="Port Scanner Detect" protocol=\
    tcp psd=21,3s,3,1
add action=drop chain=input comment="Drop to port scan list" src-address-list=\
    Port_Scanner
add action=jump chain=input comment="Jump for icmp input flow" jump-target=ICMP \
    protocol=icmp
add action=accept chain=input comment="Accept DNS - UDP" port=53 protocol=udp
add action=drop chain=forward comment="Client dc" src-address=192.168.88.103
add action=jump chain=forward comment="Jump for icmp forward flow" jump-target=\
    ICMP protocol=icmp
add action=drop chain=forward comment="Drop to bogon list" dst-address-list=\
    bogons
add action=drop chain=forward comment="Avoid spammers action" dst-port=25,587 \
    protocol=tcp src-address-list=spammers
add action=drop chain=forward comment="Client DHCP Block" src-address=\
    192.168.88.16
add action=accept chain=input comment="Accept DNS - TCP" port=53 protocol=tcp
add action=accept chain=input comment="Accept to established connections" \
    connection-state=established
add action=accept chain=input comment="Accept to related connections" \
    connection-state=related
add action=accept chain=input comment="Full access to SUPPORT address list" \
    src-address-list=support
    "Accept all connections from local network" in-interface=bridge
add action=accept chain=input comment="Accept WebFig Access from Local" \
    dst-port=80 in-interface=bridge protocol=tcp src-address=192.168.88.0/24
add action=accept chain=input comment="Accept WinBox Access from Local" \
    dst-port=81,8291 protocol=tcp src-address=192.168.88.0/24
add action=accept chain=input comment="Accept Radius UDP" dst-port=\
    1700,1812,1813 protocol=udp
add action=accept chain=ICMP comment="Echo reply" icmp-options=0:0 protocol=\
    icmp
add action=accept chain=ICMP comment="Time Exceeded" icmp-options=11:0 \
    protocol=icmp
add action=accept chain=ICMP comment="Destination unreachable" icmp-options=\
    3:0-1 protocol=icmp
add action=accept chain=ICMP comment=PMTUD icmp-options=3:4 protocol=icmp
add action=accept chain=input comment="Accept WinBox Remote" dst-port=8291 \
    protocol=tcp
add action=accept chain=input comment="Allow L2TP" dst-port=1701 protocol=udp
add action=accept chain=input comment="Allow PPTP" dst-port=1723 protocol=tcp
add action=accept chain=inpur comment="Allow SSTP" dst-port=443 protocol=tcp
add action=drop chain=ICMP comment="Drop to the other ICMPs" protocol=icmp
add action=jump chain=output comment="Jump for icmp output" jump-target=ICMP \
    protocol=icmp
add action=drop chain=input dst-port=53 in-interface=\
    ISP1-AFRIHOST-200/100-FIBRE protocol=udp
add action=drop chain=input comment="Block all access to the winbox - except to \
    support list # DO NOT ENABLE THIS RULE BEFORE ADD YOUR SUBNET IN THE SUPPORT\
    \_ADDRESS LIST" disabled=yes dst-port=8291 protocol=tcp src-address-list=\
    !support
add action=drop chain=input comment="Drop TCP Port 53" dst-port=53 \
    in-interface=ISP1-AFRIHOST-200/100-FIBRE protocol=udp
add action=drop chain=input comment="Drop UDP Port 53" dst-port=53 \
    in-interface=ISP1-AFRIHOST-200/100-FIBRE protocol=tcp
add action=drop chain=input comment="Drop anything else! # DO NOT ENABLE THIS RU\
    LE BEFORE YOU MAKE SURE ABOUT ALL ACCEPT RULES YOU NEED" disabled=yes
add action=drop chain=input disabled=yes in-interface=\
add action=drop chain=forward disabled=yes src-address=192.168.88.16
/ip firewall mangle
add action=mark-packet chain=prerouting comment="internal-traffic packet mark" \
    dst-address-list=internal-nets new-packet-mark=internal-traffic \
    passthrough=yes src-address-list=internal-nets
add action=mark-packet chain=prerouting comment=\
    "customer-servers-out packet mark" new-packet-mark=customer-servers-out \
    passthrough=yes src-address-list=customer-servers
    "customer-servers-in packet mark" dst-address-list=customer-servers \
    new-packet-mark=customer-servers-in passthrough=yes
# ether1-gateway DSL 1 not ready
add action=mark-packet chain=prerouting comment="admin-in packet mark DNS" \
    in-interface=*1 new-packet-mark=admin-in passthrough=yes protocol=udp \
    src-port=53
add action=mark-packet chain=prerouting comment="admin-in packet mark snmp" \
    dst-port=161 in-interface=*1 new-packet-mark=admin-in passthrough=yes \
    protocol=udp
add action=mark-connection chain=prerouting comment=\
    "Remote Protocols admin connection mark" new-connection-mark=admin \
    passthrough=yes port=20,21,22,23,3389,8291 protocol=tcp
    "icmp connection mark as admin" new-connection-mark=admin passthrough=yes \
    protocol=icmp src-address-list=internal-nets
add action=mark-packet chain=prerouting comment="admin-in packet mark" \
    connection-mark=admin in-interface=*1 new-packet-mark=admin-in passthrough=\
    yes
add action=mark-packet chain=prerouting comment="admin-out packet mark" \
    connection-mark=admin new-packet-mark=admin-out passthrough=yes
    "streaming video in packet mark" connection-mark=streaming-video \
    in-interface=*1 new-packet-mark=streaming-video-in passthrough=yes
    "streaming video out packet mark" connection-mark=streaming-video \
    new-packet-mark=streaming-video-out passthrough=yes
    "http traffic connection mark" dst-port=80,443 new-connection-mark=http \
    passthrough=yes protocol=tcp src-address-list=internal-nets
    "http traffic connection mark" connection-bytes=5000000-4294967295 \
    dst-port=80,443 new-connection-mark=http-download passthrough=yes protocol=\
add action=mark-packet chain=prerouting comment="http in packet mark" \
    connection-mark=http in-interface=*1 new-packet-mark=http-in passthrough=\
    yes
add action=mark-packet chain=prerouting comment="http out packet mark" \
    connection-mark=http new-packet-mark=http-out passthrough=yes
    "wow connetion mark as gaming" dst-port=1119,3724,6112-6114,4000,6881-6999 \
    new-connection-mark=games passthrough=yes protocol=tcp src-address-list=\
    internal-nets
    "eve online connetion mark as gaming" dst-address=87.237.38.200 \
    new-connection-mark=games passthrough=yes src-address-list=internal-nets
    "starcraft 2 connetion mark as gaming" dst-port=1119 new-connection-mark=\
    games passthrough=yes protocol=tcp src-address-list=internal-nets
    "heros of newerth connetion mark as gaming" dst-port=11031,11235-11335 \
    internal-nets
    "steam connetion mark as gaming" dst-port=27014-27050 new-connection-mark=\
    "xbox live connetion mark as gaming" dst-port=3074 new-connection-mark=\
    "ps3 online connetion mark as gaming" dst-port=5223 new-connection-mark=\
    "wii online connetion mark as gaming" dst-port=28910,29900,29901,29920 \
    internal-nets
    "games packet mark forever-saken-game" dst-address-list=external-nets \
    new-packet-mark=games-in passthrough=yes src-address-list=\
    forever-saken-game
add action=mark-packet chain=prerouting comment="games packet mark starcraft2" \
    dst-address-list=external-nets new-packet-mark=games-in passthrough=yes \
    protocol=udp src-port=1119,6113
add action=mark-packet chain=prerouting comment="games packet mark wow" \
    protocol=udp src-port=53,3724
add action=mark-packet chain=prerouting comment="games packet mark HoN" \
    protocol=udp src-port=11031,11235-11335
add action=mark-packet chain=prerouting comment="games packet mark steam in" \
    dst-address-list=external-nets new-packet-mark=games-in passthrough=no \
    port=4380,28960,27000-27030 protocol=udp
add action=mark-packet chain=prerouting comment="games packet mark steam out" \
    dst-port=53,1500,3005,3101,3478,4379-4380,4380,28960,27000-27030,28960 \
    new-packet-mark=games-out passthrough=yes protocol=udp src-address-list=\
    internal-nets
add action=mark-packet chain=prerouting comment="games packet mark xbox live" \
    protocol=udp src-port=88,3074,3544,4500
add action=mark-packet chain=prerouting comment="games packet mark ps3 online" \
    protocol=udp src-port=3478,3479,3658
add action=mark-packet chain=prerouting comment="games packet mark in" \
    connection-mark=games dst-address-list=external-nets new-packet-mark=\
add action=mark-packet chain=prerouting comment="games packet mark out" \
    connection-mark=games new-packet-mark=games-out passthrough=yes
add action=mark-packet chain=prerouting comment="voip-in packet mark teamspeak" \
    dst-address-list=external-nets new-packet-mark=voip-in passthrough=yes \
    protocol=udp src-port=9987
    "voip-out packet mark teamspeak" dst-port=9987 new-packet-mark=voip-out \
    passthrough=yes protocol=udp src-address-list=internal-nets
    "voip-out packet mark teamspeak" dst-address-list=external-nets \
    new-packet-mark=voip-in passthrough=yes protocol=udp src-port=9987
add action=mark-packet chain=prerouting comment="voip-in packet mark ventrilo" \
    protocol=udp src-port=3784
add action=mark-packet chain=prerouting comment="voip-out packet mark ventrilo" \
    dst-port=3784 new-packet-mark=voip-out passthrough=yes protocol=udp \
    protocol=tcp src-port=3784
    dst-port=3784 new-packet-mark=voip-out passthrough=yes protocol=tcp \
add action=mark-packet chain=prerouting comment="voip-in packet mark SIP" \
    dst-address-list=internal-nets new-packet-mark=voip-in passthrough=yes \
    port=5060 protocol=tcp
add action=mark-packet chain=prerouting comment="voip-out packet mark SIP" \
    new-packet-mark=voip-out passthrough=yes port=5060 protocol=tcp \
add action=mark-packet chain=prerouting comment="voip-in packet mark udp SIP" \
    port=5004,5060 protocol=udp
add action=mark-packet chain=prerouting comment="voip-out packet mark udp SIP" \
    new-packet-mark=voip-out passthrough=yes port=5004,5060 protocol=udp \
add action=mark-packet chain=prerouting comment="voip-in packet mark RTP" \
    dst-address-list=internal-nets new-packet-mark=voip-in packet-size=100-400 \
    passthrough=yes port=16348-32768 protocol=udp
add action=mark-packet chain=prerouting comment="voip-out packet mark RTP" \
    new-packet-mark=voip-in packet-size=100-400 passthrough=yes port=\
    16348-32768 protocol=udp src-address-list=internal-nets
add action=mark-packet chain=prerouting comment="vpn-in packet mark GRE" \
    in-interface=*1 new-packet-mark=vpn-in passthrough=yes protocol=gre
add action=mark-packet chain=prerouting comment="vpn-out packet mark GRE" \
    new-packet-mark=vpn-out passthrough=yes protocol=gre
add action=mark-packet chain=prerouting comment="vpn-in packet mark ESP" \
    in-interface=*1 new-packet-mark=vpn-in passthrough=yes protocol=ipsec-esp
add action=mark-packet chain=prerouting comment="vpn-out packet mark ESP" \
    new-packet-mark=vpn-out passthrough=yes protocol=ipsec-esp
    "vpn-in packet mark VPN UDP ports" in-interface=*1 new-packet-mark=vpn-in \
    passthrough=yes protocol=udp src-port=500,1701,4500
    "vpn-out packet mark VPN UDP ports" new-packet-mark=vpn-out passthrough=yes \
add action=mark-packet chain=prerouting comment="vpn-in packet mark PPTP" \
    in-interface=*1 new-packet-mark=vpn-in passthrough=yes protocol=tcp \
    src-port=1723
add action=mark-packet chain=prerouting comment="vpn-out packet mark PPTP" \
    new-packet-mark=vpn-out passthrough=yes protocol=tcp src-port=1723
add action=mark-routing chain=prerouting in-interface=all-ppp new-routing-mark=\
    to_ISP1 passthrough=no per-connection-classifier=src-address-and-port:2/0
    to_ISP2 passthrough=no per-connection-classifier=src-address-and-port:2/1
add action=mark-connection chain=prerouting comment="UPSTREAM CONNECTION" \
    in-interface=ISP1-AFRIHOST-200/100-FIBRE new-connection-mark=All-Inconn \
    passthrough=yes
add action=mark-packet chain=prerouting comment=UPSTREAM connection-mark=\
    All-Inconn new-packet-mark=All-inpkt passthrough=yes
add action=mark-connection chain=forward comment="DOWNSTREAM CONNECTION" \
    in-interface=ISP1-AFRIHOST-200/100-FIBRE new-connection-mark=All-Outconn \
    passthrough=yes
add action=mark-packet chain=forward comment=DOWNSTREAM connection-mark=\
    All-Outconn new-packet-mark=All-Outpkt passthrough=yes
add action=mark-packet chain=forward comment="SAMODIEN DOWNSTREAM" dst-address=\
    192.168.88.101 new-packet-mark=samo-pkt packet-mark=All-Outpkt passthrough=\
    yes
add action=mark-packet chain=forward comment=DOLLIEDOWNSTREAM dst-address=\
    192.168.88.102 new-packet-mark=dollie-pkt packet-mark=All-Outpkt \
    passthrough=yes
add action=mark-packet chain=forward comment="DOMINGO DOWNSTREAM" dst-address=\
    192.168.88.103 new-packet-mark=dom-pkt packet-mark=All-Outpkt passthrough=\
    yes
add action=mark-packet chain=forward comment="HENDRICKS DOWNSTREAM" \
    dst-address=192.168.88.104 new-packet-mark=hend-pkt packet-mark=All-Outpkt \
    passthrough=yes
add action=mark-packet chain=forward comment="BARDIEN DOWNSTREAM" dst-address=\
    192.168.88.105 new-packet-mark=bard-pkt packet-mark=All-Outpkt passthrough=\
    yes
add action=mark-packet chain=forward comment="ATTA DOWNSTREAM" dst-address=\
    192.168.88.106 new-packet-mark=atta-pkt packet-mark=All-Outpkt passthrough=\
    yes
add action=mark-packet chain=forward comment="ABDOL DOWNSTREAM" dst-address=\
    192.168.88.107 new-packet-mark=abdol-pkt packet-mark=All-Outpkt \
    passthrough=yes
add action=mark-packet chain=forward comment="KILIAN DOWNSTREAM" dst-address=\
    192.168.88.108 new-packet-mark=kilian-pkt packet-mark=All-Outpkt \
    passthrough=yes
add action=mark-packet chain=forward comment="MASTER DOWNSTREAM" dst-address=\
    192.168.88.2 new-packet-mark=Master-pkt packet-mark=All-Outpkt passthrough=\
    yes
add action=mark-packet chain=forward comment=Samodien-Down connection-bytes=\
    1000000-0 new-packet-mark=samo-dpkt packet-mark=samo-pkt passthrough=yes \
    protocol=tcp src-port=80,443
add action=mark-packet chain=forward comment=Dollie-Down connection-bytes=\
    1000000-0 new-packet-mark=dollie-dpkt packet-mark=dollie-pkt passthrough=\
    yes protocol=tcp src-port=80,443
add action=mark-packet chain=forward comment=Domingo-Down connection-bytes=\
    1000000-0 new-packet-mark=dom-dpkt packet-mark=dom-pkt passthrough=yes \
add action=mark-packet chain=forward comment=Hendricks-Down connection-bytes=\
    1000000-0 new-packet-mark=hend-dpkt packet-mark=hend-pkt passthrough=yes \
add action=mark-packet chain=forward comment=Bardien-Down connection-bytes=\
    1000000-0 new-packet-mark=bard-dpkt packet-mark=bard-pkt passthrough=yes \
add action=mark-packet chain=forward comment=Atta-Down connection-bytes=\
    1000000-0 new-packet-mark=atta-dpkt packet-mark=atta-pkt passthrough=yes \
add action=mark-packet chain=forward comment=Abdol-Down connection-bytes=\
    1000000-0 new-packet-mark=abdol-dpkt packet-mark=abdol-pkt passthrough=yes \
add action=mark-packet chain=forward comment=Kilian-Down connection-bytes=\
    1000000-0 new-packet-mark=kilian-dpkt packet-mark=kilian-pkt passthrough=\
add action=mark-packet chain=forward comment=SAMO-Streams layer7-protocol=*6 \
    new-packet-mark=samo-spkt packet-mark=samo-pkt passthrough=no
add action=mark-packet chain=forward comment=DOLLIE-Streams layer7-protocol=*6 \
    new-packet-mark=dollie-spkt packet-mark=dollie-pkt passthrough=no
add action=mark-packet chain=forward comment=DOMINGO-Streams layer7-protocol=*6 \
    new-packet-mark=dom-spkt packet-mark=dom-pkt passthrough=no
add action=mark-packet chain=forward comment=HENDRICKS-Streams layer7-protocol=\
    *6 new-packet-mark=hend-spkt packet-mark=hend-pkt passthrough=no
add action=mark-packet chain=forward comment=BARDIEN-Streams layer7-protocol=*6 \
    new-packet-mark=bard-spkt packet-mark=bard-pkt passthrough=no
add action=mark-packet chain=forward comment=ATTA-Streams layer7-protocol=*6 \
    new-packet-mark=atta-spkt packet-mark=atta-pkt passthrough=no
add action=mark-packet chain=forward comment=ABDOL-Streams layer7-protocol=*6 \
    new-packet-mark=abdol-spkt packet-mark=abdol-pkt passthrough=no
add action=mark-packet chain=forward comment=KILIAN-Streams layer7-protocol=*6 \
    new-packet-mark=kilian-spkt packet-mark=kilian-pkt passthrough=no
add action=mark-packet chain=forward comment="SAMODIEN BROWSING" \
    connection-bytes=0-1000000 new-packet-mark=samo-bpkt packet-mark=samo-pkt \
    passthrough=no protocol=tcp src-port=80,443
add action=mark-packet chain=forward comment="DOLLIE BROWSING" \
    connection-bytes=0-1000000 new-packet-mark=dollie-bpkt packet-mark=\
    dollie-pkt passthrough=no protocol=tcp src-port=80,443
add action=mark-packet chain=forward comment="DOMINGO BROWSING" \
    connection-bytes=0-1000000 new-packet-mark=dom-bpkt packet-mark=dom-pkt \
add action=mark-packet chain=forward comment="HENDRICKS BROWSING" \
    connection-bytes=0-1000000 new-packet-mark=hend-bpkt packet-mark=hend-pkt \
add action=mark-packet chain=forward comment="BARDIEN BROWSING" \
    connection-bytes=0-1000000 new-packet-mark=bard-bpkt packet-mark=bard-pkt \
add action=mark-packet chain=forward comment="ATTA BROWSING" connection-bytes=\
    0-1000000 new-packet-mark=atta-bpkt packet-mark=atta-pkt passthrough=no \
add action=mark-packet chain=forward comment="ABDOL BROWSING" connection-bytes=\
    0-1000000 new-packet-mark=abdol-bpkt packet-mark=abdol-pkt passthrough=no \
add action=mark-connection chain=forward comment="YouTube DL Conn Mark" \
    in-interface=ISP1-AFRIHOST-200/100-FIBRE layer7-protocol=YouTube \
    new-connection-mark=YouTube_DL_Conn passthrough=yes
add action=mark-connection chain=forward comment=Netflix_Conn in-interface=\
    ISP1-AFRIHOST-200/100-FIBRE layer7-protocol=Netflix new-connection-mark=\
    Netflix_Conn passthrough=yes
add action=mark-packet chain=forward comment=Netflix_Packet connection-mark=\
    Netflix_Conn new-packet-mark=Netflix_Packet passthrough=no
add action=mark-packet chain=forward comment=YouTube_DL_Packet connection-mark=\
    YouTube_DL_Conn new-packet-mark=YouTube_DL_Packet passthrough=no
add action=mark-connection chain=prerouting comment=YouTube_UP_Conn \
    in-interface=bridge layer7-protocol=YouTube new-connection-mark=\
    YouTube_UP_Conn passthrough=yes
add action=mark-packet chain=forward comment=YouTube_UP_Packet connection-mark=\
    YouTube_UP_Conn new-packet-mark=YouTube_UP_Packet passthrough=no
add action=masquerade chain=srcnat comment="default configuration" \
    out-interface=ISP1-AFRIHOST-200/100-FIBRE to-addresses=0.0.0.0
# no interface
add action=masquerade chain=srcnat out-interface=*11
add action=masquerade chain=srcnat dst-address=192.168.88.0/24 src-address=\
    192.168.88.0/24
/ip proxy
set anonymous=yes enabled=yes max-cache-size=none port=53281
add check-gateway=ping distance=1 gateway=ISP1-AFRIHOST-200/100-FIBRE \
    routing-mark=to_ISP1
add check-gateway=ping distance=1 gateway=*11 routing-mark=to_ISP2
add check-gateway=ping distance=2 gateway=*11
add distance=1 dst-address=192.168.88.0/24 gateway=192.168.88.2
add distance=1 dst-address=192.168.88.3/32 gateway=*F00002
add distance=1 dst-address=192.168.88.50/32 gateway=bridge
/ip route rule
add action=lookup-only-in-table dst-address=192.168.88.0/24 table=main
/ip service
set telnet disabled=yes
set ftp disabled=yes
set ssh disabled=yes port=2222
set api disabled=yes
set api-ssl disabled=yes
/ip smb shares
set [ find default=yes ] directory=/pub
/ip ssh
set allow-none-crypto=yes forwarding-enabled=remote
/ppp aaa
set use-radius=yes
/ppp secret
add name=spideradmin profile=default-encryption service=pptp
/radius
add address=192.168.88.2 service=ppp,login
/radius incoming
set accept=yes port=1700
/system clock
set time-zone-autodetect=no time-zone-name=Africa/Johannesburg
/system logging
set 1 action=echo
/system script
add dont-require-permissions=no name=script1 owner=admin policy=\
    ftp,reboot,read,write,policy,test,password,sniff,sensitive source="/ip firew\
    all filter\r\
    \n\r\
    \nadd action=drop chain=input comment=\"Drop to syn flood list\" disabled=no\
    \_src-address-list=Syn_Flooder\r\
    \nadd action=add-src-to-address-list address-list=Port_Scanner address-list-\
    timeout=1w chain=input comment=\"Port Scanner Detect\"\r\
    \ndisabled=no protocol=tcp psd=21,3s,3,1\r\
    \nadd action=drop chain=input comment=\"Drop to port scan list\" disabled=no\
    \_src-address-list=Port_Scanner\r\
    \nadd action=jump chain=input comment=\"Jump for icmp input flow\" disabled=\
    no jump-target=ICMP protocol=icmp\r\
    \nadd action=drop chain=input\r\
    \ncomment=\"Block all access to the winbox - except to support list # DO NOT\
    \_ENABLE THIS RULE BEFORE ADD YOUR SUBNET IN THE SUPPORT ADDRESS LIST\"\r\
    \ndisabled=yes dst-port=8291 protocol=tcp src-address-list=!support\r\
    \nadd action=jump chain=forward comment=\"Jump for icmp forward flow\" disab\
    led=no jump-target=ICMP protocol=icmp\r\
    \nadd action=drop chain=forward comment=\"Drop to bogon list\" disabled=no d\
    st-address-list=bogons\r\
    \nadd action=add-src-to-address-list address-list=spammers address-list-time\
    out=3h chain=forward comment=\"Add Spammers to the list for 3 hours\"\r\
    \nconnection-limit=30,32 disabled=no dst-port=25,587 limit=30/1m,0 protocol=\
    tcp\r\
    \nadd action=drop chain=forward comment=\"Avoid spammers action\" disabled=n\
    o dst-port=25,587 protocol=tcp src-address-list=spammers\r\
    \nadd action=accept chain=input comment=\"Accept DNS - UDP\" disabled=no por\
    t=53 protocol=udp\r\
    \nadd action=accept chain=input comment=\"Accept DNS - TCP\" disabled=no por\
    t=53 protocol=tcp\r\
    \nadd action=accept chain=input comment=\"Accept to established connections\
    \" connection-state=established\r\
    \ndisabled=no\r\
    \nadd action=accept chain=input comment=\"Accept to related connections\" co\
    nnection-state=related disabled=no\r\
    \nadd action=accept chain=input comment=\"Full access to SUPPORT address lis\
    t\" disabled=no src-address-list=support\r\
    \nadd action=drop chain=input comment=\"Drop anything else! # DO NOT ENABLE \
    THIS RULE BEFORE YOU MAKE SURE ABOUT ALL ACCEPT RULES YOU NEED\"\r\
    \ndisabled=yes\r\
    \nadd action=accept chain=ICMP comment=\"Echo request - Avoiding Ping Flood\
    \" disabled=no icmp-options=8:0 limit=1,5 protocol=icmp\r\
    \nadd action=accept chain=ICMP comment=\"Echo reply\" disabled=no icmp-optio\
    ns=0:0 protocol=icmp\r\
    \nadd action=accept chain=ICMP comment=\"Time Exceeded\" disabled=no icmp-op\
    tions=11:0 protocol=icmp\r\
    \nadd action=accept chain=ICMP comment=\"Destination unreachable\" disabled=\
    no icmp-options=3:0-1 protocol=icmp\r\
    \nadd action=accept chain=ICMP comment=PMTUD disabled=no icmp-options=3:4 pr\
    otocol=icmp\r\
    \nadd action=drop chain=ICMP comment=\"Drop to the other ICMPs\" disabled=no\
    \_protocol=icmp\r\
    \nadd action=jump chain=output comment=\"Jump for icmp output\" disabled=no \
    jump-target=ICMP protocol=icmp"
Why??
https://www.comparitech.com/blog/vpn-privacy/the-pptp-vpn-protocol-is-not-secure-use-these-alternatives-instead/
Use IKEv2,
OR the default Ipsec L2TP available on quickset. Recommended by Doctors and Normis! :slight_smile:
Hi
Thanks for the response!
Will clicking apply on quickset not change all my current settings/scipt e.g ISP dial and PPPoE server?
Sure it will, don’t touch quickset if you have already done some settings some other way.
Switching from PPTP to L2TP encrypted using IPsec can be done without using quickset, and it is easy, but doing so will provide “only” much more security to the VPN connection, it will not solve your issue.
What exactly means that setting arp to proxy-arp has caused a standstill of the network? Is the Mikrotik the default gateway for the devices on its LAN?
