PPTP cant see other ressources over VPN
Hi
I know, a lot of others had asked this question, but i didn’t find a solution for my problem. I have configured a PPTP connection and i can connect successfully to my vpn. But i can’t access other pc’s or my nas storage. I have tried different things:
  1. The IP Pool for the VPN Clients had a different ip range than the clients inside the network (10.0.0.x)
  2. The VPN Clients got as remote adress a IP from the internal dhcp pool (192.168.2.x)
I can ping the router - but nothing else. My subnetmask is 255.255.255.255 (dont know why). and the gateway is also 0.0.0.0…
IPv4-Adresse . . . . . . . . . . : 192.168.2.99
Subnetzmaske . . . . . . . . . . : 255.255.255.255
Standardgateway . . . . . . . . . : 0.0.0.0
I also tried to enable arp-proxy - bt i’m not sure if i have to enable this for every port on the router (router has different ethernet ports) or just on the WAN port (fiber).
Any tips for me? I’m glad for any help!
Thanks a lot
