However there is still something not working. I see packets flowing through the out interface and Mangle rule, but they are not returning.
It works however if I set a Local Address on the profile.
Am I right to assume that both the Local and Remote Addresses should both be from the VPN range?
How can I set the router to get a dynamic IP from the VPN side?
I tried to set a DHCP Client, but the interface pptp-out1 is not available to choose from, and if I choose the ether1-gateway it never gets any IP…
Local and Remote IP are now - OK.
It was a misconfiguration under the PPP profile (Use Encryption required a yes).
Still, I can sniff the ping packets, they leave with the correct IPs, but never return…
I have a NAT masquerade for the pptp-out1
A mangle that I confirm the packets are passing through
A route with destination 0.0.0.0/0, gateway pptp-out1, routing mark same as Mangle rule
Do you think I am lacking something else?
Maybe some firewall rule I don’t know where else to look for the missing config.
I’ve already done it, but still nothing.
I’m starting to think this is a server side problem since I did the exact same thing with a different server and got it to work on the first try.
I guess it’s some problem associated with multiple ips on same account, or something related to mac addresses, not sure.
